Your pics aren't showing up. Just a bunch of X's
Yep, data transfer rate exceeded...........I'll put up some smaller pics, and repost when it lets me...........
Don't think you will have the room, mount the cooler in front of the condenser.
OK, just checked mine and there is 1" maybe 11/2" between radiator and condenser. But you will not be able to go through the radiator bracket with your oil cooler lines.
The thickness of the side plate: front mounting surface to fan shroud mounting surface (outside to outside) 2 15/16"The distance from the core to the fan shroud mounting surface (inside to inside) 1/2"Thickness of core (header tanks don't matter) As I mentioned above 1 7/8"
What exact part number is this? As it looks like it's doable.....thanks
http://www2.partstrain.com/store/?PN=6887&N=0&VN=+4294967152+4294966916+4294967242+4294963189+4294967046&Nr=AND(year:1986,make:Toyota,model:Pickup,submodel:Base Turbo,engine:4 Cyl 2.4L,universal:0)scroll down to cooling system and click on radiator. I like the silla 3 row aluminum radiator.
I was talking about the one that's all aluminum.
Started by rckbldr New Announcements and Info
Started by 94runner Toyota Pickup/4Runner Tech 1979-95
Started by Volcom Colorado
Started by kamakazecam Bumpers, Cages, and Tube Benders
Started by theslayer85 CB and HAM Radio Tech
