This will be my first 4link, but everything i have read says this should be ok. But is a 60" lower link to much?Let me know what all you think?
60" is way to long you will be draging your lower links on everything and it will make ledges/stairs very difficult Shoot for 40" lowers and 30" uppers.
i would also try at the least to keep the top of your joint level with the bottom of your frame, if not higher.
Thats the only part I'd disagree with. IMO, you just want flat links. If you have a low ride height, like you do, then you can get away with your heims being tucked up that far. Other wise leave them low and build them to slide over stuff.
Started by 83yota General 4WD Discussion
Started by JoeShmo65 Toyota Pickup/4Runner Tech 1979-95
Started by madmanweaver444 Toyota Pickup/4Runner Tech 1979-95
Started by BigMike New Announcements and Info
