1984 4Runner ***SOLD****
Started by MarkyB, August 02, 2009, 04:52:20 PM
MarkyB
OK. It SOLD.  $3500  I'm keeping the winch and tires.  Located in Mobile, AL.  I will meet someone with it a reasonable distance (3-4hrs away) if you pay what I'm asking.
1984 4Runner. Body is in good shape. Some rust, some trail rash. I've only cut off the tabs for the lower plastic. I painted it myself with Krylon rattle cans. (So it doesn't bother me to scratch it.)
1 inch body lift.
Axles are still stock, 4:10s, welded front and rear. New front brake pads last year, rears didn't need changing. I did a J-arm ball flip, but have the parts to return it to stock plus a drop drag link. I have an extra 3rd member, carrier, 4:10 R&P, no spiders, and 2 sets of front inners and 1 birf. And a set of stock front springs.
I bought parts to do a hydro assist, but have not put it on yet.
Springs are custom mix & match Toyota and Junkyard stuff with poly bushings.
Carbed 22R with only an S&B OEM rplacement filter.  Odometer reads 245000 but the previous owner rebuilt the motor. It starts right up and runs like a top. No smoke or valve ticking. There is a small oil leak on the bottom of the motor that I was told is caused by the rebuild mechanic not using the correct seal. I was told it would be easy to fix, but I just put a little engine oil stop leak in it and that stopped it for a while.
No issues with the trans at all. I have installed 4.7 gears in a top shift case and run that in the truck now. I have the stock forward shift t-case I was saving for a future doubler.
I bedlined the interior with red Durabak. (not the prettiest job, but it's a trail rig.) I still have all the interior pieces, except the carpet.
I have a cut top on it, but also have a complete top to go on it.
I currently have 33 ProComps on it but might keep them. The aluminum rims can go with it though. I also have the stock steel rims for it.
I also have a hydraulic winch on it, but I'm wanting to keep that too.
bigarms23
a fairly clean rig like this id start at 4500 as a base price
MarkyB
