83 Toyota Pickup Crawler DD FS
Started by kevin286, July 29, 2009, 01:59:06 PM
kevin286
I'm selling my 83 Toyota.
Bought several years ago stock and rusty.
Gotta get rid of it. I'm getting out of the sport to save for a house. Make me an offer.
Located in Bozeman Montana. Local pickup unless you want to pay to ship it.
$5000 or best offer.
Motor:
22r Rebuilt, .040 over, 261 cam and rebuild kit from engnbldr
Doug Thorley header
Carb has all emissions removed and blocked off
140Amp GM 1 Wire with 4xinovations GM alt bracket
4xinovations poly motor mounts with roger brown 2" engine lift
Brakes:
Stock disc up front
Stock for 86' Drums rear
New MC from Marlin with larger bore
Line Lock front 'E-brake'
Stainless extended brake lines from Marlin
Axles:
Front cromo inners from Marlin (US Alloy)
Bobby Long 27 spline birfs
Rebuilt hubs w/new bearings etc with Marlin rebuild kit
High Steer 4 stud kit billet steel Marlin with Fox dampner from PP
IFS Box w/ TG flat arm. Pump shimmed a little bit. No whine
Front 3rd with 5.29 Yukon w/detroit locker
Front axle rotated the right (although PITA) way for correct pinyon pointing
Rear axel and housing from 86 IFS truck
Rear 3rd with Yukon 5.29 R and P welded carrier. Square plate method
Rear axle pinyon rotated as well by moving spring perches
Tires:
>90% Tread on Big O 35". Spare is also Big O with > 90%
Drive:
Stock L52 Steel housing 5 Speed
Stock T-case with TG 4.7 low range gear set kit
Stock rear driveshaft
2" receiver tube front driveshaft.
Custom T-case mount also 2" higher than stock to match engine height
Mickey Thompson Classic 2 15" Wheels with drain petcock installed
Suspension:
Front Mazda/Toyota Rear hybrid pack
TG shock hoops
Front 14" Bilstien 5125s
Rear Deaver 61.5" leafs from PP
Rear 14" Bilstien 5125 included but not installed
Body:
Stock cab with 1" BL also from Roger Brown
Front custom bumper from 2" .120 wall tube
Rear custom bumper from 2"x3" .120 wall tube w/2" receiver built in
Rust in the floor boards was cut out and patched with sheetmetal from a suby
Custom bed. Top rail dimentions sized to fit small short bed topper.
Interior:
New headliner tan
New Carpet and carpet jute tan
New suspension seats bought here on Pirate with 4 point harnesses. Very awesome
Accessories:
Warn M8000 Winch 3/8 syn rope
Dual Batteries
ATV winch setup over rear axle w/in cab control
Rock lights at all corners
OBA (cosco compressor and 5gal tank)
CB Radio firestick 2 antenna
1/2 doors
Comes with:
Rear 14" NIB Bil 5125 shocks and weld on brackets
stock Birfs
stock front axles
IFS stearing box
NIB clutch master cyl
OEM Carb
NIB LC Engineering timing chain kit w/metal guides
Recovery bag with tow straps, clevises, air gauge
All extra leaves from the Deaver and hybrid packs
Axle brackets to build anti wrap bar
Full regular doors w/good glass
High lift jack
Anything else 4x related I can find.
Pictures:
Gallery
'94 4Runner, 3.0, Downey HD Coils, Edelbrock IAS Shocks, K&N Drop-in, ARB Bull bar w/warn M8000
'83 Toy longbed. 35"s on MT Classics, DP bed, Post '86 rearend, 5.29s, rebuilt .040 over, 216cam, warn m8k w/syn rope, MC hysteer, bla bla.
