Backing plate eliminator?
Started by puunui, July 16, 2009, 11:40:13 PM
puunui
Do you need to run that backing plate eliminator or can you do with out it and just take off the backing plate?
skyscraper
You need it I'm pretty sure, because if you dont run it the placement of the seal that bolts to it will be off.
88_Pathy
Or you can trim down the stock one.
4RunnerChevy
Yes you do need it, its also a spacer and seal.  I just cut the center from my backing plates, and used them.
puunui
thank you. I'll put them back on.
