V6 has a slite miss
Started by hacksaw, October 21, 2004, 05:54:52 AM
hacksaw
I have an 88 SR5 regular cab 4x4 with the V6 engine.  The engine runs great, does not smoke, does not rattle, has great power, but has what seems like a very slite miss through out the rpm range.  The engine only has a slite "shake" to it at idle speeds and you can realy only hear a very slite missing sound from the tail pipe.  If you hold the throttle at different rpm ranges steady you can hear the engine go back and fourth from a miss to a non miss.  I have changed the plugs, wires, cap and rotor, fuel filter, and air filter.  I have also installed a new stock muffler and there is still no change.  Like I said before, no smoke, no noise, and perfect looking old plugs when I changed them.  But it still has that little miss???  I need help it is driving me NUTTSSSSSSSSSSSSS!  Thank you.  Email [email protected] for a possible fix idea?  Thanks
Bone stock 94 Runner.  3VZE, 4x4, 5 speed.  204K miles and counting------96 Runner Limited 4x4, 3.4L Automatic, 144K miles and going strong!
toyrokcrwlr
Vacum advance hose are cracking and leak air, try looking at all the little hose going into the intake.
mr4x42u
yea,,i would look for a vaccume leak also..a vac gauge should find it,,if you have a leak you should have unsteady vac..
