Engine Re-build Kit!!!!
Started by SWAMPER, October 18, 2004, 08:26:28 PM
SWAMPER
I dont know what you tried to do up there Glen but they dint even have the 4Runner on there all they had on model were cars
88runner
Quote from: LILSWAMPER on October 21, 2004, 02:04:53 PM
:smack: you see the menu "make" go down and chose toyota TRUCK  :slap:
:greengrin:
88 4runner v6,
5.29 with 35" tires,
Isuzu Rodeo rear disk brake,
solid axle'd
SWAMPER
from what it looks like  about $200 for gaskets and bearings,  did you get a rundown of all the cylinders  compression??
SWAMPER
No sir sure dint so besides the engine rebuild kit i would have to get all those 200 bucks worth of bushings and gaskets?
Mike D
#36
 check out www.autopartsgo.com really gasket kits
Link should work now
Quote from: LILSWAMPER on October 21, 2004, 04:03:39 PM
bearings and gaskets would  :shocking: BE  :shocking: the rebuild kit, and a set of rings
SWAMPER
Quote from: LILSWAMPER on October 19, 2004, 12:51:45 PM
My truck does not smoke at all...I think that a valve job on #4 would do the trick....I will check the pricing for this whenever I talk to the mech...and if its not a big diff to rebuilt the whole thing I might just have it rebuilt anyways Ill keep you guys updated :thumbs: Mike thanks for all your info :beerchug:
yea there should be a big difference,  not only parts but LABOR  :thumbdown:
125,000 ?  unless you had bad oil pressure i wouldnt bother taking the pan off
power wise,  all the little things add up,  many compliment each other, like a cam and larger valves, and a bored throttlebody,  since you gotta pull the head or heads might as well ad a mild cam,
SWAMPER
Yeah thats what I was thinking getting a mild cam oversized valves and porting and polishing my heads...how many monies would P&P add?
P&P is usually charged by the hour,  but you could probably figure $100/ head EASY
http://www.doaracingengines.com/v6.html,  lots a EXPENSIVE stuff here
SWAMPER
Well if I would get that done I would get it done in my fathers friend shop in Mex...so that hourly figure you typed in drops to about....uhm...half atleast
