Sound deadner
Started by NCK4L, June 14, 2009, 11:05:10 AM
NCK4L
i was wondering if anyone knows of a good sound deadner/heatshield? Like the type you would lay on your flooring to keep heat and noise out.
Cheesemaker
Toymin8r
Joey88RUNR
i heard there is some stuff better than dynamat these days, check out the local lowes or home depot...they have some good stuff used for that
yota_krawler
house hold carpet padding!
TIMS89CRAWLER
dynamat makes the best automotive sound deadener that I am aware of.... I am not sure how well it works as a heat shield.....
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
ExploreSystems
Hello, check these guys out www.secondskinaudio.com . They have some excellent products and a great spray or bush on thermal coating called "firewall". They are out of AZ and way better than dynamat! We have used it a lot. They even produce their own bedliner. Good stuff
85 4Runner 22RE Auto W Marlin HiSteer=30 Spline Longs-V6 diffs 4:88 F&R ARBs F&R Hi Pinion Front= FJ 17" Steelies 255/70/17 BFG MT Skinnines=Marlin rear bumper...im sure there is more
NCK4L
COToy91
Quote from: Joeyotaman on June 15, 2009, 01:54:59 PM
Works great and is cheap ill see if i can find a link
