22re jeep aw4 dual yota tcase
Started by 88v6yota, October 15, 2004, 10:17:20 PM
88v6yota
I was wondering if anyone had any info on putting a jeep aw4 behind a 22re thatway I could run toyota dual tcases   any info would help
brainlessfool
Am I missing something? why would you put a jeep trans behind a 22RE? just run a W56 and call it good.
Because its next to impossible to put a crawler behind a yota auto without going through a helluvalotta trouble.
Marlin
What trans is a aw4?
Do you mean a AX4 5 speed trans?
Confused in Fresno
Marlin
kyle_22r
AW4 is the aisin-built automatic used in jeeps...and i believe supras?
88v6yota
the aw4 is also basicaly the same 4 speed auto used in toyotas(a340) only the tcase is removable so you have the ability to put a dual tcase setup behind it
81RockerToy
 :headscratch:  How tall are you Marlin?
Are you standing closer to the camera in your profile picture?
because it looks like you're a foot taller than the cab :yikes:
81RockerToy
