Author Topic: 85 4runner tail gate hinges rattle  (Read 2273 times)
Larryb
  • Turtle Points: 3
  • Male Posts: 206
  • Member since Mar '09
« on: May 28, 2009, 05:54:38 PM »
Just looking for some ideas on how to quiet my tail gate hinges with the tail gate in the closed position. Surprisingly my 4runner has very few rattles but the tail gate hinges take the cake.
jeff94runner
  • Male Posts: 138
  • Member since Jun '08
Re: 85 4runner tail gate hinges rattle
« Reply #1 on: May 28, 2009, 06:40:54 PM »
Arn't they suppose to have rubber grommets that keep them from rattling? If not that would work.
"Keeping the heavy light the heavy can be handled"
Joey88RUNR
  • Turtle Points: -23
  • Male Posts: 1,057
  • Member since Feb '08
« Reply #2 on: May 28, 2009, 06:42:10 PM »
I just wrapped them with black tape, then padded the sides with foam tape :hammerhead:
Larryb [OP]
  • Turtle Points: 3
  • Male Posts: 206
« Reply #3 on: May 28, 2009, 07:13:53 PM »
Actually the black tape and foam is one of the ideas i was thinking of. I guess great minds think alike :)  I found one rubber grommet on the drivers side of the tail gate while the pass side rubber grommet is missing. Even with the one grommet the drivers side, it still rattles as bad as the pass side.
gnob
  • Turtle Points: 486
« Reply #4 on: May 28, 2009, 10:25:07 PM »
just replace the anti rattle clips from the dealer.
hold this. . .
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
  • Member since Sep '04
« Reply #5 on: May 28, 2009, 10:34:41 PM »
Do like I do, crank up the stereo a little more.  Mine rattle like a pregnant dog and I drive a p/u.
87toyotaman
  • Male Posts: 298
  • Member since Jan '09
« Reply #6 on: May 29, 2009, 11:48:34 AM »
LOL I like that answer Cheesemaker....its amazing how many odd sounds that our toyotas make that can be covered up by cranking the stereo (exhaust leaks, a bad catalytic converter, exhaust backfire, and a rattling window)  :thumbs:
87 Turd with a lot of gadgets glued on
Larryb [OP]
  • Turtle Points: 3
  • Male Posts: 206
« Reply #7 on: May 30, 2009, 05:23:07 PM »
Thanks, i'll go down monday and order some anti rattle clips and give those a try first.
Larryb [OP]
  • Turtle Points: 3
  • Male Posts: 206
« Reply #8 on: Jul 01, 2009, 04:56:36 PM »
Do they make anti rattle clips for the 4runner? The parts dept ordered some silencers but when the parts arrived it was 2 small blocks of soft foam with double sided tape on one side. The sad part is they charged me twenty bucks for those two little pieces of foam. She is trying to tell me they do not show anti rattle clips at all for a 85 4runner.
studentwheeler
  • Turtle Points: 121
  • Male Posts: 382
  • Member since Feb '06
« Reply #9 on: Jul 01, 2009, 05:07:31 PM »
Put some heavy rubber bands around mine.
Larryb [OP]
  • Turtle Points: 3
  • Male Posts: 206
« Reply #10 on: Jul 01, 2009, 05:19:46 PM »
I put some rubber insulation at each end of the hinges which is working pretty good and was thinking of putting some inner tube over the center hinge section but wanted to know if they make anti rattle clips for a 4 runner or is that a pick up truck item only.
wifesaysimadumbass
  • Male Posts: 132
  • Member since Feb '03
  • SHUT UP HIPPY
« Reply #11 on: Jul 01, 2009, 05:33:30 PM »
dude all i know is that if you can hear any rattles on your runner you have the wrong kind of tires on it !!!
The original and still the best Environmentalists Hunters and Off roaders....
Larryb [OP]
  • Turtle Points: 3
  • Male Posts: 206
« Reply #12 on: Jul 01, 2009, 05:40:45 PM »
Actually its only low speed rattles. At hwy speeds you cant hear anything but the hum of the mudders :)
TheGaJoker
  • Member since Aug '09
« Reply #13 on: Aug 19, 2009, 07:18:24 PM »
I took some large rubber bands and wrapped mine, effective and cheap
Larryb [OP]
  • Turtle Points: 3
  • Male Posts: 206
« Reply #14 on: Aug 19, 2009, 07:39:52 PM »
Actually the best solution I found was placing bike inner tube the entire length of the hinge. Simple, inexpensive and works great
Last post Mar 08, 2004, 08:09:09 AM
by crawler#976
Last post Mar 13, 2008, 08:43:03 AM
by pyrosnow911
Last post Mar 12, 2009, 08:15:14 AM
by Slobbermouth
Last post Oct 25, 2010, 10:15:58 PM
by ToYocRawleR
Last post Sep 23, 2011, 05:08:19 PM
by Jokeass-Wheelers
