1st Gen. lift question
Started by NCRunner, October 12, 2004, 12:11:22 AM
NCRunner
Im new to the site as well as the 4x4 world and have a quick question. I have an 85 4runner and intend  on putting a 4 inch lift on it in the next few weeks. I have new brake lines and new drag link but am not sure what else i may need or problems i may run in to. Are there other steering components or anything else that i will have to change? Any help would be greatly appriciated. Thanks
Have you considered using a crossover steering system yet?
NCRunner
Thats something i might look into in the future, but i dont really have the extra money for it right now. If i had the money that would be i nice route to go though.
Id put ford shock mounts on it and longer travel shocks at the same time.  Beings as you'll already be in the area.
NCRunner
Ive heard about doing that, but i dont weld and im not sure of any places around here that do work like that. Do you just get them at a junk yard and cut them off or what?
Ill have to dig up the part number, I bought a set new for $20 at the local dealership.  They can be bolted on, actually they are riveted from the factory so it owuld not be very hard to drill and sleeve the framerails to bolt them on.
NCRunner
So is it just the top mounts? Are they a stem or eye type mount?
They are basically just a longer version of the stock mounts that use a EB1 mount instead of the SS2 mount that yotas come stock with.
NCRunner
If you have those part numbers handy i would appriciate them. If its any hassle though dont worry abuot it
I know that brandon has posted the pn as well as many others but I cant remember the # offhand.  Try a search here and on Pirates, Im sure it'll pop up.
NCRunner
No problem, thats why I get the big bucks..... :gap:
Fireimp141
Other than brake lines and ure lift kit, i dun see what is "needed" but of course some new bilsteins with long travel hoops and a crossover kit could be considered "needed" :yupyup:
DAWGTOY
hi ncrunner
  i'm from nc also (shelby area). where are you from? maybe we can wheel togather sometime.
send me a pm. have a good day.
1983 TOY SHORT PICKUP .35/12.50S EXO CAGE HOMEMADE BED CAMO PAINT, REARS UP FRONT CHEVYS IN THE REAR, 4 WHEEL DISK, CABLE LOCKER REAR, LOCK RITE FRONT, 5.29GEARS FRONT & REAR.BOBBY LONG 30 SPLINES 9500 lb WARN WINCH. DUAL
T CASES WITH 4.7 IN THE REAR. THANKS MARLIN
here are my ford shock mounts.  They are cut down about 2-3 inches.  There should be another rivit hole just below the one on there.  Mine are welded on, not bolted.
NCRunner
If i could find someone around here to weld them for me i might look at getting some ford mounts
Fireimp141
and if not it dont take much to drill 2-4 holes and put some grade 8 bolts in it, that should hold ya
NCRunner
you think that would work ok? just bolting it through the frame? i didnt know if that would be safe enough or not
Fireimp141
Yah, it would hold fine, there isnt that much stress on shocks, and plus, if u wanna really overdo it, 4 bolts would hold it on fine... seen that new ford commercial where 6 bolts hold on the trucks bed? they lifted the truck by the bed haha, so i think ure safe ;)
Mike D
by the way NCrunner your aviater is nasty :slap:
Skinny_Pedal
well u could bolt it on. then once thats done just go to a wleder and have him weld it in place. simple stuff
Im an OG
NCRunner
Alright. I may try that. Thanks for all the help guys.
Fireimp141
yotaboy79
yeah there isnt much stress on the shock towers as long as your bump stops stop the travel befor the shock bottoms out the person befor me put longer travel shocks on my rig with out a lift or hoops and it took one speed bump and my passenger side shockmount was compleatly off and my drivers side almost was :crazy: :_oops:
burnyota
enough about ford shock mounts..., what about a marlin suspension kit? isn't that what you wanted to know about in the original post? get the marlin hoops, crossover steering(marlin) etc....and build it to wheel with your own abilities
85 p/u, marlin#208, built 22R on propane, old school longs, 5.29's / detroits, bobbed, chopped, and flopped
