Relist: 1985 Toy, pickup, built, clean, street legal; $6995
Started by Tumbleweed, May 18, 2009, 04:14:29 PM
Tumbleweed
85 Toyota SR5 standard cab truck
Turn key ready wheeler!  Very reliable.
Nothing mechanical on this truck has over 20k miles since rebuild
Bed bobbed 12"
88 22RE motor about 15-20k on rebuild with LC cam, LC header, K&N filter
88-W56 5 speed trans, rebuilt with motor
T cases, dual, both rebuilt, front stock 2:28, rear 4.7 Marlin      This is the dual ultimate marlin setup
224-1 crawl ratio
Trailgear crossmember, high clearance
Centerforce II clutch, new at rebuild
5:29 gears new at rebuild and Aussie lockers front and rear, diffs got all new gears, bearings, etc
Rear axle is 1989, 3" wider than stock
Front axle is original 85, gusseted and reinforced tubes
FJ 40 vented discs, V6 4 piston calipers, wheel spacers in front, new pads
FJ80 master cylinder
Sky high clearance crossover steering
IFS steering box, moved 2" forward
FJ80 tie rod ends
37x12.50x 15 MTR's with around 75% life left
8"x15 steel rims
Spare is 37 x16.5 rim, Wrangler tire no leaks but old, same height as MTRs
Outside Roll bar is air tank for OBA, also has Scuba tank for OBA; will come with new MR-50 compressor for the OBA, 5 air chucks throughout the truck and 2 gauges
In cab roll cage
4 point RJS harness
Yellow top Optima battery
Mile Marker 8k winch/steel cable
2 speed Taurus electric fan
Ammo can console between seats
CB and K40 antennae
Custom front and rear bumpers, reciever hitch in rear, sliders, 1-1/2 tubes from front bumper around front fenders to sliders, to rear fenders, to rear bumper
(360* protection from fenders down)
Rear springs are 63" chevys, one leaf removed, dual shackles but I welded them so they can't open; rear also has coils for overloads
Front springs are Downey rears, custom home made coil over springs over Bilstein 5125 shocks
Custom antiwrap bar for rear springs, works very well
8" pipe caps welded over both diffs for guards
Front driveshaft is square receiver tubing, .250" thick
Rear slider window
All glass is good, windshield replaced 6 months ago
Rocklights- 2 up front
2 D ring mounts up front for recovery points
mudflaps on rear bumper
aftermarket tach and oil and water gauges
heat, def, clock works well
no radio or stereo
gas gauge is accurate
Left front axle outer is Longfield 27 spline, inner is stock
Right front axle is Longfield 30 spline, inner is chromo
No rust, been garaged for last 5 years that I know of.
Paint job is from Maeco, not bad and 1 year old, fleet white Dupont paint.
Roof rack is homemade and strong enough for 3 adults to stand in.
Passed Boise Idaho smog laws and have the certificate, 3 months ago
I have a clear Idaho title in my possession, not salvage, my name, and no liens.
Always use synthetic oil in engine, changed every 2000 miles.  All fluids in truck changed semi-annually.
  I typically drive it 45-75 miles to trails on the backroads; do the trails, and return home.It will get 22-23 mpg driving it easy and under 60mph.  I have driven it down the Interstate at 60-65mph and it does fine, will go faster but engine is turning near 3k and I don't push it.
The truck has a rough idle due to the cam but smooths right out at 1000 rpm.  My check engine light does come on when you get above idle.  I have run the codes and nothing.  Had the Snapon guy run the codes, and nothing.  Cornwell tool guy ran a scanner-nothing.  We suspect that the light comes on because of something in the ac harness that came with the 88 motor does not have a sensor in it.  Runs fine, no problem.  Shut the key off and idle, no light.
Three weeks ago, I resealed the front axle and used Marlins new inner axle seals, repacked wheel bearings, put on new pads, new HD pinion seal
I have an epoxy garage floor, and there are NO leaks on the truck. Have lots of spares for the truck, all hoses and belts, ps pump, spare cap and rotor, grille,  front axle seals that stuff.
I have a spare inner left, and inner right front axle, one stock birfield, and set of new MM front hubs that  go with the truck.  I have a spare set of 4 steel rims that can go with the truck, nothing special about them-and they are ugly.
Factory service manual in print included.
Hi-lift mount in bed.
Large Plastic toolbox, lockable, with rack included
Two sets of tire chains for the 37's included if you want them.
Truck runs and drives great, really smooth ride over washboards and such.
I don't use the truck to it's potential anymore.  Body is pretty clean but not perfect.  Looking to go back to a mild built Tacoma TRD xcab, or similar for more comfort, more streetable, AC, more of an adventure trail rig.
Good pic of rig in Readers Rigs mag, spring 09 issue.
$6995 or possible trade for the right  Tacoma TRD xcab, 4runner.  I am old and picky, no junk or projects to be finishe
Located in Boise, Idaho
[email protected]    208-861-6514
Pics here-
http://www.tumblwd.smugmug.com/gallery/7483754_8u6z5#482917801_uJDde
Tumbleweed
New price!
Found some other trucks I want to consider.  Let's move this truck.
you guys have Smog in So Idaho?!
we don't have crap up here in Nor Idaho.
sick truck though buddy.
good luck on the sale
Tumbleweed
46&2
Thats a hell of a deal.... bump for a very nice truck.  :biggthumpup:
kenny5150
kenny hines 5150
85_4RNR
I work a 2000 BMW 540i 6 speed
85_4RNR
Ok that guy needs to stop bumping old threads. I'm getting really pissed
acreves
Quote from: 85_4RNR on December 23, 2010, 06:18:19 AM
I reported his post but I wish they would ban him. Almost all of his posts are bumping all these old for sale adds.
85_4RNR
Kenny is just learning the ropes, give him some time :thumbs: Besides, you can't argue that this is a nice truck :eyebrow:
ROCKSTOMPER185
who cares if you are getin pisted off kennys cool and duzz good bizzness
banning someone for bumping old threads is barely ban worthy... maybe not right, but shouldn't be ban worthy...... sometimes life is annoying, doesn't men i want to end it..
ROCKSTOMPER185
The guys that need 2 be band are the guys that set up a deal and tell you a day then wont anser there post on here give you a number then wont anser it after talked all week sent pics wat they were salin. I have no problem with someone changin there mind and they tell me thats cool.
Hottrod81
Sparkplug
Yeh kenny is cool dude man, he just new to forums thing, give him a break man, he nice dude
thegoofster21
Quote from: Sparkplug on December 24, 2010, 09:26:00 AM
im sure he is just tell him to look before posting
Quote from: crawlerdad on October 08, 2009, 08:21:17 PM
Any guy who takes his woman wheeling enjoys her. A woman who is owned is left at home to cook, clean, and keep beer cold. So if this offends you you should stop looking and go have some tacos.    :rofl2: And a beer. If your old enough.   :beerchug:   :beer:
04 Tacoma 33s http://board.marlincrawler.com/index.php?topic=61454.0
jmoffroad.com
kenny5150
im sorry if your piissed but wasnt sure what all that ment now i do but i think its  lame if that pissed  you off i was just bummpen some old threads that were still for sale there is alot more to life then gettn pissed about lame crap so grow up and realize you are being lame and your not god so dont judge me instead of banning a guy give him some tips im sure you are not perfect in any way grow up crybabie
kenny hines 5150
84t0y
Quote from: kenny5150 on December 24, 2010, 12:21:15 PM
ya he totally seems like a real nice guy.
85_4RNR
The thing is you were bumping trucks that were SOLD ALREADY. It Frustrates people who are looking to by a rig just like the ones you're bumping because then they find out it's an outdated thread and the truck is sold.
Crybaby? Wow
kenny5150
you dnt knw me and that's fine you can have your own opinion i just saw that the rig said  RELIST in title so i was confused has that ever happend to you MR PERFECT
kenny hines 5150
kenny5150
HOPE YOU DNT HAVE KIDS THAT FRUSTRAETES YOU SO YOU CANT BANNED THEM
kenny hines 5150
thegoofster21
go to pirate4x4 and try this and see how it works out for you the people on marlin crawler easy going, but when you do the same thing over and over and then we tell you what you are doing wrong and then call us caybabie's damn. just read when it was first posted and then see when the last post was done.
and  :welcome:
jmoffroad.com
85_4RNR
Sparkplug
kenny5150
i read the add. get over it it already happend if you would like to chat in person come hit me up sure we could come to a understanding
kenny hines 5150
kenny5150
and by the way its crybabie. and was only inteaded to those who where doing the crying
kenny hines 5150
SamuelEngelking
84 Toyota Ext, 5.29's Locked Up, 4.7's, 37's KM2, 17" KMC Wheels,
Hydro assist, Propane, Headers, Body Armor, Some Bump In The Trunk..
acreves
I reported the post because I am looking for another truck and for several days these old post were being brought back up to the top. It was brought to your attention in several of the other adds. I was hoping the mods would have a feature to ban you from posting in the Rigs For Sale section. I am done crying now. I am now laughing at you calling others "crybabies" instead of manning up and saying my bad it won't happen again.
