well hopefully all the 3.4 parts i need get here early this week and i would like to have the trans mission mated to the transfer case and ready to go in by next weekend but i still haven't ordered the the gears or the adapter for the line up the hardest part of doing this is the exhaust crossover (i wish off-road solutions still was in business) and trying to tell a local shop what i need is like telling a 3 year old to do algebra.... they want to but they just don't get the pointhttp://www.toyonlyswaps.com/ will take your crossover as a core and do it for youi have a tank for a 3rz with a fuel pump in it but i am still not sure if i should do that or just get an aftermarket inline and use the tank i have to run my fuel system.... if any one knows anything about this give me some ideas i cant find any info on any of the forums that give good detail on how they did the fuel delivery This tank and pump should work fine. People are running these with 22re pumps, mine is using a 3.0 tank and pump since it is a 92 runnerthen the other is what do i do to get my tach to read right going from a 22r to a 3.4 the speed is in the t case all of the other sensors i think i can figure out but i am not sure if i need to put a resistor in the cluster?You will need to solder a resistor on the back of the tack for it to read correctly. Swap your oil pressure sensor onto the 3.4 block and that will read fine. No issues with the coolant temp. All these will get wired in between the dash harness and the engine harness.
Started by Caboose « 1 2 » Chit Chat Camp
Started by 84Yota Toyota Pickup/4Runner Tech 1979-95
Started by Kurlee Daddee Toyota Pickup/4Runner Tech 1979-95
Started by 87hillbillyoter « 1 2 3 » General 4WD Discussion
Started by Lobo176 Newbie Questions
