sas kit questions
Started by cj_92_hunt, April 20, 2009, 07:12:17 PM
cj_92_hunt
I have a 1997 nissan hardbody that im wantin to do a sas on would the toyota kit work with a few modification? :confused:
bigarms23
maybe but did you see the sas kits for nissians from calmini but i dont see why it wouldn't
cj_92_hunt
no i did not see the kits from them ill take a look at them
89sastoyo
I would buy what ever is cheaper the only thing I see not working with the solid axle swap kit for a toyota is the frame jigs where you drill the holes for the shackles. The reason that might not work its because the frame on a nissan might be at a different angle then the toyotas is. Also would you be buying the whole IFS eliminator kit or just the spring hanger and tubes for the shackles?
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
