Author Topic: brake help  (Read 1696 times)
FruitaCrawler
  • Turtle Points: -174
  • Male Posts: 36
  • Member since Aug '05
brake help
« on: Apr 15, 2009, 12:36:59 PM »
i have a 2000 chevy silverado as my DD/tow rig. the problem that im having is that the brakes seem to take more pressure to stop now then when i bought it about 7 months ago. also the parking brake doesnt seem to work at all when i set the brake the light on the dash flashes and if you put the truck in gear it doesnt feel like it is grabing at all. where should i look first? i have checked to pads and they have plenty of matterial left.
88 pickup- stock for now
America has always had on imigration problem just ask any indian
Hyena
  • I'm Legit!!!
  • Turtle Points: 2401
  • Male Posts: 6,715
  • Member since Feb '04
  • AKA Baja Brad
Re: brake help
« Reply #1 on: Apr 20, 2009, 10:03:43 PM »
make sure you have the propper amount of fluid.  your parking brake probably needs to be adjusted as they do stretch also.
FruitaCrawler [OP]
  • Male Posts: 36
Re: brake help
« Reply #2 on: Apr 24, 2009, 08:33:15 PM »
The Fluid is right where it needs to be. Is the aadjustment of the brake cable something i can do or do i need to take it to a shop?
Cheesemaker
  • Turtle Points: 1363
  • Male Posts: 4,525
Re: brake help
« Reply #3 on: Apr 26, 2009, 05:29:36 PM »
Your e-brake cables run along the outside of the drivers side frame.  Look for a section where you can tighten up a nut on a threaded section.
Do you have disc brakes on the rear?  If you got drums, adjust up the adjusters, so the shoes just slightly drag the drum when you spin the axle.
  • Momentum Man
  • Turtle Points: 730
  • Male Posts: 13,860
  • Lego Enforcement
    • Spinnin4s 4x4 Club
Re: brake help
« Reply #4 on: Apr 26, 2009, 05:48:56 PM »
Make sure the rears are working, I'm assuming this since the pb isn't working either could just need to be adjusted.
FruitaCrawler [OP]
  • Male Posts: 36
Re: brake help
« Reply #5 on: Apr 27, 2009, 10:26:54 AM »
Yeah it has disc in the Rear. I Guess i am off to the parts store to pick up a manual and try to adjust that PB cable
Last post Feb 15, 2003, 09:02:06 AM
by BigMike
brake help!
Last post May 30, 2004, 03:24:18 PM
by WHITE_TRASH
Last post Oct 16, 2004, 07:46:08 PM
by KYOTA
Last post Dec 23, 2007, 11:47:07 AM
by KYOTA
Last post Jan 11, 2008, 10:40:25 PM
by jimbo74
