Having Major Issue tcase won't shift
Started by AreYouSure, March 24, 2009, 05:44:00 PM
AreYouSure
I just rebuilt a forward shift transfer case of mine and for some reason i amstuck in 2wd low with the 4wd light on.  i am unable to shift out of low range gear.  i hope it is an easy fix.  what do you all think the issue is.
Lots of work Done to Truck After a Few Deployments
Want To see How I am Making Money
http://j81hatala.blogspot.com/
:ack:  i think we're gonna need a pic
or a little better description
93tonkatoy
When you installed the gearbox/t-case, did you have the shift rails in the 4 HI position (both pushed fully toward the engine)? If not, your shifter may be "stuck" in one of the shift rails, with the interlock pin preventing abnormal shifting patterns.
SAVE TELLICO post 491
rage
Quote from: 93tonkatoy on March 24, 2009, 09:10:49 PM
Take it apart and fix it. The interlock pin is jamming or installed improperly.
I learned i had this problem, when i had the same symptoms as you i just kicked the shifter until it moved. Well, it did. Had to toss that case because i bent both shift rails, and then turned the round holes in the case the rails slide in into big egg shaped holes. And the interlock key came out in pieces.
Quote from: rage on March 26, 2009, 09:39:11 AM
i think you possibly learned that kicking the shifter was bad :rofl:
82 HiLux
yeah next time instead of kicking it use a rubber hammer!  the transfercase linkage is simple, just take it apart and then make sure it shits properly before you bolt it all back together
