little 20r update
Started by red runner, March 18, 2009, 07:35:47 PM
red runner
you guys where right keep my eye on my oil and yep its going threw oil pretty darn good  :hammer: its not leaking or anything but going into the radiator =/ head gasket i asume .....my question is ...is there anything off the shelf that could fix the problem for a short time my buddy said they call it liquid glass you put it in ur oil run it for like 10 min or so and then change ur oil .....its just for work and back the truck and i dont really wanna tear into it anything you guys can think of besides tear down ...which i might just have to do.....let me kno THANKS!!   :thumbs:
if you have some hand tools, ratchet, sockets 12mm,14mm,17mm,19mm  you can change the headgasket in 2-4 hours
red runner
ill just do it this weeknd right on
red runner
i wonder what the chances of having a cracked or worped head i heard those 20r's are pretty tuff
wakkjobb
Never hurts to have the head checked by a shop; or use a straight-edge and check yourself if you know what to look for. You didn't overheat it, right? You should be okay since aluminum can be damaged easier than iron/steel heads. I'd see about having the head resurfaced a little just for good measure/peace of mind.
:twocents:
Good luck with it!
Dan
