Author Topic: chevy springs or marlin springs  (Read 3993 times)
Lil Bax
  • Member since Mar '09
« on: Mar 14, 2009, 05:02:38 PM »
i just got my 83 yota and want to do somethign to the suspension it already has blocks in the rear but rides like a horse and buggy. what should i do go with the chevy swap or buy the marlin springs im kinda new to all this so please help thanx
Re: chevy springs or marlin springs
« Reply #1 on: Mar 14, 2009, 05:35:41 PM »
i personally run F150 springs on Marlin hangers
yota_krawler
  • Cody Hunter
  • Male Posts: 3,379
  • proud parent!!!
« Reply #2 on: Mar 14, 2009, 06:52:50 PM »
depends on what you want. 60 dollar springs or 300 dollar springs... I got a set of 2wd 63's, I havent put them in yet but they seem to work pretty good.
yotabj
  • Turtle Points: -15
  • Male Posts: 116
  • MAD FLEX YO!!!!
« Reply #3 on: Mar 15, 2009, 12:27:53 PM »
$60 rock anchor or $300 for a decent spring. I have run F150's/Mazda's on the rear but I hated my shackles dragging the ground. I opt'd for Marlins 4" front springs in the rear and made my shackles go thru my frame for better departure. Of course they are kinda stiff but I will be removing a leaf at a time till I like it. I would rather have a stiffer ride than worry about my hanger/shackles dragging everywhere.
'84  Truggy EFI swap ,5.29's Detroit,welded,Dual Ultimate Cases,22re,3 in. downey,4 in.Marlin Front springs on back  114 wb ,39.5 Rockers,30 Spline Longs
87pickup
  • Turtle Points: 33
  • Male Posts: 719
  • Member since Jul '07
« Reply #4 on: Mar 15, 2009, 02:50:21 PM »
I am real happy with my 4" Marlins. They flex good and im not constantly hung up on them like i see with 63" chevy's. I might pull the bottom overload out to see what it does.
twistedtoy92
  • Turtle Points: -255
  • Male Posts: 3,781
  • NFM Customs
« Reply #5 on: Mar 15, 2009, 02:57:33 PM »
Im running the 64'' chevy's with 6'' shackles along with 53'' toy rears upfront custom packed with 4.5'' shackles...... i love em!
Yoat Goat
  • Turtle Points: 37
  • Male Posts: 731
  • Member since Aug '07
  • Someday my truck will look like this
« Reply #6 on: Mar 15, 2009, 03:40:03 PM »
You could run S-10 springs, a few peps on here are running them with good results. Im getting ready to put em under my truck.
T urning
O ver after
Y ears
O f
T rail
A buse
yota_krawler
  • Cody Hunter
  • Male Posts: 3,379
  • proud parent!!!
« Reply #7 on: Mar 16, 2009, 09:35:53 AM »
I have heard of s10s as well. I thought about it, but I got chevys instead.
do you got pics? what did you mix the springs with? I am way interested. I had rears up front on my 85 but not the 53" ones. hat does it do for axle relocation?
TIMS89CRAWLER
  • Turtle Points: 35
  • Male Posts: 1,968
  • Member since Oct '07
  • BORN TO WHEEL, FORCED TO WORK...
« Reply #8 on: Mar 16, 2009, 09:42:40 AM »
I say save the cash and run the chevys.....  I have marlins and wouldnt spend the cash on them again.... you can build very good working/riding packs from chevys
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
twistedtoy92
  • Male Posts: 3,781
  • NFM Customs
« Reply #9 on: Mar 16, 2009, 10:23:43 AM »
Check out my build, I think i have the specs on there!!! the rears were free (off the back) and the chevy's were $75 from the wrecking yard.... sky sells a good chevy spring bracket kit and i used marlins kit upfront but used marlins rear hangers under the frame for the front! my front has 7 leafs right now but i am going to repack them with a couple stiffer chevies for more uptravel to my bump stops.... they work vey well! Its one of those experimentation deals.... just play untill they work how you want them too!
Last post Nov 11, 2004, 03:25:00 PM
by kneedownnate
Last post Jan 24, 2005, 12:25:37 AM
by mr4x42u
Last post Jan 28, 2005, 06:41:46 AM
by MiniSimp
Last post Apr 13, 2005, 07:37:39 AM
by TRDISMO
Last post Jul 28, 2005, 02:06:26 PM
by KYOTA
