Red Yota
Started by lifted_drifter, March 04, 2009, 06:53:03 PM
your shackle angle won't be so shitty.
and you won't bottom out your shackle before your compression cycle is done.
89sastoyo
i would wheel it first.. i know a few people who didnt move theres and its actually better in the end if your going for a low frame hieght and want flex because you'll have a lot of droop and not much uptravel which is nice. Also you can make bump stops so the shackles won't actually hit the frame when completely uptravel.
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
lifted_drifter
Yeah i am def gonna try it out first.
I was thinking i could also do a two piece shackle if that doesnt work out and it would "move" the top pivot point of the main shackle. I guess it looks worse in pics, there is a lot of room for it to up travel still, i treid to max out the suspension today, which was dumb because the stock front hangar is still there :(
we should have the plasma cutter back tmw so i can get rid of that then it will be play time :)
lifted_drifter
Drove out of the shop today! :)
Still have to fix up the e brake and bleed the breaks alot better.
But the fact that it actually works is very good :) :)
GJToyotabug
looks sick man what size are those tires again?
BGrednckyoter
Quote from: GJToyotabug on May 07, 2009, 08:25:31 PM
they are 35 1250s
89sastoyo
looks really good for sure i like the stance i'd deffinetly leave the shackle less work and might as well see how it does.
92 2wd DD
first gen cab
lifted_drifter
They're only 35x12.5
Tryin to get some 37's
Its all done i just have to get it aligned if anyone knows a good tech arcticle for aligning high steer. I have been looking for one and i cant find any.
lifted_drifter
And i will leave the shackle and see how it does, hopefully test it out this weekend.
lifted_drifter
i tested out the truck today.
not so sure i like how the front works. .. . . . . i think i'm gonna have to repack the springs.
89sastoyo
Quote from: lifted_drifter on May 08, 2009, 08:21:34 AM
What i do is just take a tape measure take the tires off measure from rotor to leaf, Lign the pitman arm straight and steering wheel straight make sure you are where you want everythign when its straight then adjust from there. Doing the Tie Rod you will just measure that both rotors are the same distance in the front on both sides and on the back aswell. I always go about an 1/8 inch closer to the spring in the front then the rear. For the drag link just get everything even then crank one way then the other and measure how far away the front rotor is from the spring on each side repeat and adjust untill they are even both turning left or right.
92 2wd DD
first gen cab
lifted_drifter
#101
Got the alignment done!
And i got a bunch of pictures! Took my truck out memorial day weekend camping and busted the balljoint on the pitman arm and somehow sheared the nut off the end of it. Going to go to a flat pitman to fix this. Luckily electrical fence wiring holds things together well, but all in all a pretty sketchy fix.
My new pitman arm should be in tomorrow, while waiting i made an exhaust to replace the ghetto status straight pipe i had. Its really really quiet but i think i like it alot better! Oh yeah and i welded everything up except the muffler which i clamped so i can switch them out easily if i ever get bored :)
Here are lots of pics.
lifted_drifter
pictures acting funny
these should be the ones of the pitman and our little campout
lifted_drifter
another
its only allowing me one pic per post
lifted_drifter
lifted_drifter
lifted_drifter
lifted_drifter
GJToyotabug
purdy exhaust man i like it. i also think its time for dual cases in it too  :yupyup:
lifted_drifter
Ha me too! and the best part is the total cost of my exhaust build was about $24 even!
I got bored today and started fixing this ghetto thing that was in place of my thrid brake like.
so heres the start of my JDM status shaved third brakelight haha.
GJToyotabug
lifted_drifter
ya i was bored.
i'm trying to figure out what trucks actually had that stock though. i just looked at my friends 86 and 87 and neither of them seemed to have ever had that light there at all.
GJToyotabug
usually not i havent seen a single 2nd gen with a third eye
lifted_drifter
wow really? i assume mine had one at a some point because of the wierd plate thingy that was there when i got it and my buddy has an 84 same color and everything an his has that light there. ill see if i cant get a picture of it.
