Author Topic: instantaneous loss of power '02 7.3 PSD  (Read 3457 times)
BLACKDOG
  • 3.0 Killer
  • Turtle Points: 718
  • Male Posts: 7,644
  • Member since Aug '04
  • I used to fit
« on: Mar 02, 2009, 10:58:02 PM »
So my truck occasionally has a sudden loss of power, its instantaneous, gives a little jolt, and then comes right back up.  Seems like it always happens when I'm driving in wet weather, but it does occasionally happen when its dry.  It kinda had me leaning toward an exposed wire that was getting wet, but I'm not sure.  Conveniently, when I checked my mail I had a service announcement from ford stating my Camshaft Positioning Sensor has not been replaced yet, was wondering if that could be related?
              -Ronald Reagan
red
  • Turtle Points: 199
  • Male Posts: 1,616
  • Member since Jan '05
Re: instantaneous loss of power '02 7.3 PSD
« Reply #1 on: Mar 03, 2009, 02:48:26 PM »
i've seen it happen before because of that sensor. should be a free replacement for your truck
read and comment :whip:
USAF EOD tech
BLACKDOG [OP]
  • 3.0 Killer
  • Male Posts: 7,644
  • I used to fit
« Reply #2 on: Mar 03, 2009, 05:04:00 PM »
It is indeed.  Guess I'll take it down there then :gap:
              -Ronald Reagan
Hyena
  • I'm Legit!!!
  • Turtle Points: 2401
  • Male Posts: 6,715
  • Member since Feb '04
  • AKA Baja Brad
« Reply #3 on: Mar 03, 2009, 07:54:48 PM »
you will most likely get less fuel mileage with the new CPS, i did when mine was replaced!  not sure if that is related to your problem though.
red
  • Male Posts: 1,616
« Reply #4 on: Mar 04, 2009, 02:32:23 PM »
only way getting a new cps could affect fuel economy is if when it was replaced the injection pump was advanced
USAF EOD tech
Hyena
  • I'm Legit!!!
  • Male Posts: 6,715
  • AKA Baja Brad
« Reply #5 on: Mar 05, 2009, 05:34:30 AM »
they didn't touch anything else on my truck, just the CPS.  Got roughly 2 mpg less.  its all over powerstroke forums too, most people claim to get less.
toytank
  • Turtle Points: 7
  • Male Posts: 354
  • Member since Sep '06
  • ROCKSOLIDMOTORSPORTS
« Reply #6 on: Mar 05, 2009, 07:53:09 AM »
i dont think that it would be the sensor but i would get it replaced. underneth the high pressure oil pump there is a white plug in its you fuel pre heat element which is famos for shorting out . it's i lil exspensive. what you can do to check it is unplug it and go under the dash find the 30 amp fuse i think its number 4 or 5 down the right ahnd side it should be blown replace it and see if that fixes your problem.
old and sqeaky but she goes
864runnershortened
  • Male Posts: 18
  • Member since Mar '06
« Reply #7 on: Apr 09, 2009, 05:35:48 PM »
The 7.3 powerstroke doesn't have a injection pump.
86 4Runner: 30 Longfields, Chomomly rear axles, , Hi-pinion front with ARB,  Spool rear,  Marlin MC-7 Dual case adapter, 4.7 gears in both cases, Champion Beadlocks, 39.5 Iroks, Rear 4 link, Hydro assist, On-board welder
red
  • Male Posts: 1,616
« Reply #8 on: May 19, 2009, 06:44:07 PM »
umm, all diesels have an injection pump. some brands call them rotary pumps but ford didnt use that style pump on the 7.3L, during this era only dodge used a rotary pump in the big 3 diesel truck market. now the newer diesels use a common rail setup but the 7.3L never came with that.
USAF EOD tech
toytank
  • Turtle Points: 7
  • Male Posts: 354
« Reply #9 on: May 21, 2009, 07:40:28 AM »
the 7.3 uses a high presure oil pump to lock the injectors in place and they are electronicly contoled by the pcm and the cpu.
Last post Jan 10, 2007, 06:38:09 PM
by mickeyfinn
Last post Mar 23, 2009, 03:34:29 PM
by unclejpl4x4
Last post May 31, 2010, 08:42:08 PM
by wakkjobb
Last post Dec 10, 2010, 09:58:43 PM
by yoshaleng
Last post Apr 20, 2011, 02:48:22 PM
by twistedtoy92
