Author Topic: ??????????????? bolting on RF1A behind a 2000 3.4 Automatic tranny  (Read 2182 times)
Ahbustae86
  • Member since Mar '09
I'm in the process of planning a 3.4 motor swap into my 91 4 runner.  I was thinking of doing the Dana 44 wagoneer axle up front, but I really wanted to use my 85 front axle thats already geared and locked.  I am using the Automatic tranny that came with the 2000 3.4. I guess what I'm trying to do is find a way to get my transfercase to drop on the passenger side. My question is how easy will it be to mate the RF1A to my 3.4 auto tranny and what parts do I need?
84xcab
  • Male Posts: 261
  • Member since Oct '07
http://marlincrawler.com/transfer-case/t/c-adapters/1995-2004-5vz-fe-34-liter-v6-drivetrains
Ditch the chain driven case. Don't go through the hassle trying to adapt it.
Bobbed 84 xtra cab, pickin up parts as I go.
If at first you do not succeed, put it in 4low and try again.
Ahbustae86 [OP]
Are you saying to ditch the idea of mating the RF1A and just use a Dana 44? or adapt the RF1A, but make sure to use the gear driven one.
dniel
  • Male Posts: 194
  • Member since Feb '09
 Use the gear drive case if you want pass. drop. Marlin makes an adapter and so does inchworm. If you want to clock it make sure the marlin adapter clocks in the direction you want. I used the inchworm adapter and it will clock in either direction. Don't be afraid to buy from inchworm Jim is a great guy and his customer service is top notch.
1uz-fe, 1 tons, 44" tsl
84xcab
  • Male Posts: 261
It would be so much easier to run a gear driven case (gear driven is from a 4 cyl truck) then trying to use your old chain drive case. Chain drives are basically a dead end since you cant use them for dual cases or anything.
Ahbustae86 [OP]
84xcab- Thanks for the input.  Have you adapted the RF1A to a Tacoma auto trans before?
84xcab
  • Male Posts: 261
Sorry bro, i completly spaced out and was thinkin that the RF1A was a chain drive. All you need to adapt your RF1A t-case to it is marlins adapter I listed in the link above. The things I meant are not worth it to adapt are the VF1A, VF2A, and A340H chain drive t-cases.
« Last Edit: Mar 03, 2009, 07:24:18 PM by 84xcab »
Ahbustae86 [OP]
Thanks.  Yeah, I would only use the gear T/Case cause I might want to go all out and upgrade to Dual case and gears.
Last post Jul 05, 2004, 06:06:22 PM
by bammarocktoy
Last post Aug 15, 2006, 08:56:52 AM
by bruiz05
Last post Sep 15, 2006, 10:50:37 PM
by toy85ota
Last post Jan 05, 2008, 12:50:35 PM
by Huhwhye
Last post Jun 27, 2011, 06:59:23 PM
by Rockin4Runner
