Daily Treads
Started by BigMike, September 24, 2004, 12:47:57 AM
I'm just curious if anyone who uses their rig as their daily driver and saves their "Rock" wheel+tires for play, what do you use for daily driver tires?
I know alot of people use BFG Alterrains but Im looking for something more :stopit: than that, something inexpensive but about 35"
Probably Im looking for some dump tire brand that is only measured in the xxxmm/rim size/profile. I dont even know what a 15" wheel and the same size as about 35" is using that method of measure. Anyone know of a good tire size converter/calculator on the web?
I plan on using my truck for alot of highway miles, visiting friends all over Cali and I dont want to waste MTRs on the pavement. Any suggestions?
Thanks
I guess these tires aren't so :stopit: to begin with.. $139 on tirerack.com isn't so bad. 35X12.50X15
These are much too :gay:
Good year Wrangler SR-A
These aren't so bad for daily driver..
Kumho Road Venture AT KL-41
So now you know what Im looking for, post up some ideas!
What size is 235/75-15 in inches?
Just $96 bucks!
So I plan to have two complete tire sets with their own wheels of course. For driving around town or playing in the mountains I'll run my MTRs, but for the highway I will slap something else on an  :driving:
Anyways, its late and im :sleeping: probably can tell huh :shocking: WAKE UP!!!! :smack:
Skinny_Pedal
used tires are always nice! cheap to
Im an OG
These are pretty cool but they dont make them in the size I need :yupyup: I hear they are like rock climbing shoes, they grip rocks on the trail so good they dont need any tread :thumbs:
Quote from: 86runner on September 24, 2004, 12:59:24 AM
I guess once I learn how that works I'll just slap on what ever I can get my hands on for cheap and save the money doughnuts for offroad
Skinny_Pedal
Im an OG
iNfErNaL
I beleive it's either a 30 or a 31.
WWW.GLOBALOFFROADSUPPLY.COM
Support Your Local Brawlers
www.RockBrawlers.com
www.offroadtruckshow.com
Quote from: Infernal Jeep on September 24, 2004, 01:09:21 AM
ok, way to small then heh
nice burn out smoke show tires though
Skinny_Pedal
Im an OG
supratruck
With a  P-metric tires size, the closest to a 35" tire is 315/75-16(which I believe is the current LC size). It look like aspect ratio is limited to 75 series which in order to get that tall a tire forces the rim size up to a 16". I belive this size also requires a minimum 8" rim width probaly 10" to be stable.
GrimReaper
Those BFG KO's do pretty darn good in most stuff but mud. I know a lot of folks that run them and I am concidering it as well. A bud has a used set for 32's for $230 for 5. I think I may buy once some of my junk sells. They ride good as well. I ran the previous AT on one of my trucks and was quite happy. They wear like IRON.
Costco sells them about $140 mounted and ballanced with road hazard. Still have to pay taxes.
cebby
I ran BFG AT 32's on my 93 4Runner for over 85K miles (2 sets).  They are really decent tires.
UZswap.com
A site dedicated to sharing info for swapping the Toyota/
Lexus UZ (V8) engines into Toyota Trucks and 4Runners.
My 4Runner
Just some parts for sale - not much else at the moment...
TOOLandFAB.com
A discussion forum dedicated to tools, fabrication & workshops
My JD2 Bender Hydro Conversion
Ok cool. Thanks for the experiences, I'll try to find some ATs then-
derek
here are some cheap tires.
work ok for daily driving.
http://www.high-tec-retreading.com/sizes.html
derek
BCB
big mike ill sale you my 35" bfg all-terrains about 6000 miles on them sale them for 375 for 4.     15"
CruzrDave
Hey Mikey I got some 37's with your name on them  :toilet:
Taking back America, one part at a time! :madeinusa:
kyle_22r
235s are pretty small, about 28.5".  i think it's the stock size on '79-83 trucks
Fireimp141
Lol, 31? i had 235/75/15, they are 28X8 tires lolz... a wee bit small unless u need another 4 inches of clearance ;)
Fireimp141
KYOTA
Mike,   Randy's R&P has a bunch of usefull calculators on his site
http://www.ring-pinion.com/calculators/calculatorsind.html
Skinny_Pedal
Im an OG
KYOTA
oops sorry, you can kiss my buttocks now :moon:
Skinny_Pedal
Quote from: KYOTA on September 24, 2004, 06:10:58 PM
my avatar says it all there buddy
Im an OG
cebby
Quote from: Fireimp141 on September 24, 2004, 04:33:48 PM
and also, 315s are 33's
315/75/16 is 34.6"    :headscratch:  (according to Randy's calculator)
UZswap.com
My 4Runner
TOOLandFAB.com
88runner
#26
Quote from: BigMike on September 24, 2004, 12:58:31 AM
235x0.75/25.4x2+15= 28.877952755905511811023622047244" so it's almost 29"
235 = width of the tire in mm
0.75 = percentage of the width of the tire = height of a side wall
25.4 = 1" = 25.4 mm or 2.54 cm
2 = 2time the height of a side wall
15 = rim dimension
88 4runner v6,
5.29 with 35" tires,
Isuzu Rodeo rear disk brake,
solid axle'd
SWAMPER
uhm....yeah that or just go here and calculate alot more than only tire sizes http://www.bncoffroad.com/ratio/   :beerchug:
burnyota
I run 35 BFG MT's on the road and around the local areas, I also run 36 swampers depending on what the conditions are going to be, and if i am driving to hte trail or sticking it on a trailer
85 p/u, marlin#208, built 22R on propane, old school longs, 5.29's / detroits, bobbed, chopped, and flopped
Skinny_Pedal
Quote from: LILSWAMPER on September 25, 2004, 09:04:49 AM
swamp if u go to the caculator that kyota and i posted then u would relieze there is more than just a tire caculator u  :moon:
Im an OG
