axle wrap
Started by BCB, September 23, 2004, 09:10:08 AM
BCB
hey do any of you guys have any serious axle wrap.  well i do i lost my driveline last night.  my friend was with me and said everytime i hit my brakes backing down the rock the hole axle wraped a bunch.  do any of you guys have this problem or had this problem.  if so what did you guys do to fix it       traction bar?
brainlessfool
are you running some big blocks on the rear?
BCB
Im talking the front the son  b wraps bad.  all pro 5" springs and kit
I've never seen anyone build a traction bar for the front....
Build something like this one from Front Range Off Road:
BCB
have you ever heard if anything like this before or had any problems. thanks for the pic  gives alot better idea of what to do
iNfErNaL
I've never heard of that happening to the front.My bro runs the same All Pro springs and he's never experienced that(at least not that I know of).The front generally doesn't wrap because you've got the weight of your engine...You might want to check to see if maybe your U bolts are a little loose.
WWW.GLOBALOFFROADSUPPLY.COM
Support Your Local Brawlers
www.RockBrawlers.com
www.offroadtruckshow.com
BCB
hey when you put a front traction bar on would you have to make it have slip in it so the driveline would still slip..   and could just run a single bar with joints on each end.  instead of like a step style bar
brainlessfool
A traction bar would have to go on where the spring is atteched soild to the frame. so on a yota it would have to go on the front.
now that being said, a trac. bar like the one mikey posted up that has a shackle on it would go on the back. butt it would not stop all the wrap as it would have some flex in the shackle. butt it would likely stop enuff to do the job. and no a slip jount would just defeat the porpuse. (where a pic. of Flipper when you need one? )
