Standard SAS or RUF
Started by yjay, February 21, 2009, 07:56:37 PM
86bobbedtoy
yeah I used f150s front and had to inboard the shackles because the springs are so long
Hey Yjay, also man, keep an eye out for a 90-95 4Runner V6 SR5 for me out your way, I am still looking.
I can make it out your way easily. I'm there quite often. hopefully this damn flu goes away  :sick:
you want the same thing, only 22RE right?
Ramrod
I dont think the 51" RUF springs would have any advantage.  the 48" ones most of the time can easily max out a 14" shock, having any more flex than that is retarded and you are going to have driveshaft and steering issues.  I did and would again go with RUF without a doubt.  You can bolt them right into your stock hangers without any issues
Rockcrawlintoy
yup i was maxin out my 13 inch shocks no problem
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
84t0y
hmm  i guess ill just use the 48s then, i have both so thats why i asked. sweet that means less work!
Jordan7118
My vote is for 48" RUFs.
You need to search on Pirate for more info.
I used first gen rears from a 4wd with a set of 3" lift springs (they weren't really a lift...) cut down on the bottom.
Save yourself $300 or so and build the springs.
if you have the $$$ to spend on the kit.... screw the hassle.
yeah RUFs are nice.. .and you gain 1" more of forward placment.... you can always swap out the main and military wrap for a rear one.. if that extra 1" is needed. I'll give you a hand in installing your kit. we can knock it out in 1 weekend.
yjay
I'll keep my eyes peeled. 22re 2nd gens aren't too hard to find, especially on the west side, are you sure you want a 3.0?
22re Daily Driver
http://board.marlincrawler.com/index.php?topic=56568.0
91 4Runner-R151f, MC07,23 spline duals, Marlin 1200lb clutch, 85 Front axle, Leaf swap rear, Yukon 5.29's, BFG KM2 35's, Detroit, OBA, 280k
Quote from: yjay on February 27, 2009, 04:44:19 PM
Yeah I am sure.
better platform if I have to go 3.4L or 4.3L TBI
and they come stock with slightly lower axle gears.
and if you're patient and willing to spend a little money.. they can be a decent motor.
plus the 22RE is underpowered for these heavy pigs IMHO.
So yes V6 :thumbs:
when you think you'll need me to come down and help you swap that pig?
toyyota
I went with rear up front because the spring packs are already broken in. I have more faith in used Toyota springs than new aftermarket. All of the suppliers keep changing manufactures, you don't what you have until after you run them, then its to late. I made my pack with two rear sets, three long leafs on top. and cut to fit the rest. A chop saw with cut off wheel cuts them like butter. I ended up with a total of seven leafs in each pack. There is plenty of room for 37's (I installed them) but i'm running 35's. As for the rear...I went with 63" Chevy's. This may be a mistake? The ride height is perfect, truck sits level, but I worry a little about axle wrap, (springs are soo long).
yjay
#40
It's probably gonna be a month or two. I need to sell the jeep and buy my wife something so I can commandeer her cherokee. Then I can build at my pace, unlike on my jeep where it always had to be ready by monday. I'm gettin' itchy.
I knew I had to have a 22re when I used to watch my uncle pull a stock trailer with 6 cows in it up the road to his place in 1st gear pegged for 3 miles over and over with no ill effects.
I'm not going to get anywhere in a hurry, I just love them. Hoping for only marginally disgusting mileage, but we'll find out.
My 93 v6 runner auto got 13mpg always.
22re Daily Driver
Quote from: yjay on February 27, 2009, 06:37:01 PM
It's probably gonna be a month or two. I need to sell the jeep and buy my wife something so I can commandeer her cherokee. Then I can build at my pace, unlike on my jeep where it always had to be ready by monday. I'm gettin' itchy. If your building a v6, doesn't that limit your t case options?
at the moment.... I don't wheel hard enough to need any tcase upgrade.
when that time comes. Ill swap in a R151F (22RTE 5spd) and run dual 2.28s.
For now stock engine/trans/tcase will be fine for me.
main thing I want to swap out soon as I can afford to, is axles and suspension.
yjay
I think if I wasn't building a DD, I'd do chevy 1 tons with spools, cheap and nasty strong.
22re Daily Driver
Quote from: yjay on February 27, 2009, 06:49:12 PM
well that's the logic choice.
DD status is the only reason I chose not to and stay Toy Axles.
yjay
22re Daily Driver
not a bad deal... :P
March 17th is when I'll have full cash :gap:
yjay
Wish I had 8k cause this is exactly what I want, even the color.
http://sacramento.craigslist.org/cto/1053765624.html
22re Daily Driver
man he is selling that now?! damn it lol. his is the one that pretty much wanted me to build one. I love how white ones look.
Also YJay, I'll help you out with your whole swap and lift... if you'll do the same when I am ready (welding) kind of a trade off?! haha
Should be lots of fun.
yjay
Thanks. I don't think I'll need much physical help, just lots of info. Let me know if you need any welding. I've got torches and a flux core welder, and my buddy down the street has a new 220 mig that's sweet. Glad to help whenever I can. I fancy myself a pretty fair welder, you can look at my work and judge for yourself. Just got done putting a hp dana 44 under my buddy's cherokee, I built the upper control arm mounts with rubicon express superflex joints instead of the typical rubber or poly ones. I also just built a rear traction bar for my rig with weld in inserts and 1.25" qa-1's. Kinda long drive unfortunately.
22re Daily Driver
SICK man.
yeah I think ill have you do some work for me.
I am more then glad to help and give info.
dniel
The thing I liked best about the ruf is you know exactly what you have. When I was doing the suspension on my old for runner alot of companies were selling Chinese springs and there were alot of confusion about who was selling what. Stock Toyota springs are made from very high quality steel and rarely break even with repeated negative arching. They are already broke in and should not sag very much. If they do sag their doing you a favor so just cut your fenders.
I used the 51" rears and they flex great and ride like a caddy on the road. To use these you will need to buy or make a front hanger and move it forward.
1uz-fe, 1 tons, 44" tsl
so you saying you don't know what you're getting when you buy AP or MC Kits or springs? they use the same spring company...
Jordan7118
Quote from: dniel on March 01, 2009, 08:57:43 PM
I don't think that's what he's saying.
TheCookieMonster
if you have a lot of money and have nothing to spend it on get a kit... but if you like to save money and have something that works just as good or better build your own spring packs. all you need are some old springs, brain :idea:, chop saw, and a tape measure. then you can spend your money on things you cant build  :thumbs: :twocents:
yjay
I built the springs for my yj. It wasn't that big of a deal. But when I looked at buying all the sas parts I'll need one at a time, it costs about the same as the kit but you don't have the springs :dunno:
I don't have a lot of bread to work with, but the more I look at the kits the better deal they seem to be for all the stuff you get.
22re Daily Driver
Quote from: yjay on March 02, 2009, 06:07:15 AM
:yupyup:
I had MC's 4in SAS kit as well as the MC Knuckle Rebuild w/ Wheel Bearingsfor the 85.
very well put together.
twistedtoy92
i run 51's packed with 48's and other leafs.... love em!!  work great!!! but i need to move my steering box forward pretty soon!!
86rustbucket
Quote from: Hunter on February 26, 2009, 10:21:16 PM
RUF!!!!! thats what I did on my old toy and I loved em! they are comparable to a marlin spring.... if you build them right. I put mine up against a marlin front spring and they preformed just as good.... For way less money!
what mix of springs did you use, iwant to build mine right the first time
yoshaleng
#59
here's a link to how my sas w/ kit looks like.....look and tell me what you guys think.... :driving:
 https://post.craigslist.org/manage/1302922277/fg793
here's what it's equipped w/:
Trail Gear 5" sas lift kit w/ 14" Bilsteins (kit kicked my front axle forward 2 3/4")
5" rear lift kit w/ 14" Bilsteins
6 shooter high steer kit
Yukon 5.29's F/R w/ Full Detroits
Dual cases freshley installed
36"x14.5x15 Swampers TSL Radial wrapped around 15x10 ProComp D152 streetlocks
square tubing front drive line
rear driveline built by DRIVELINE in Fresno
front bumper was built by a good buddy of mine and i
