speedometer cable delete
Started by bhigdon101, February 18, 2009, 06:13:58 PM
bhigdon101
i know most of you guys are not running a speedometer cable so what are
you doing in the place of it..
so nothing can get in or out....
thanks brian higdon..
daddy always said "if your going to be stupid, you better be tough"
boggerunner
bhigdon101
anyone else?
this is the only fix i got..
i am sure you can find a threaded plug or pipe endcap at the hardware store
zman2day
I left the speedo gear in and put the rubber cap that came on one of my AN hydro fittings on it.
TIMS89CRAWLER
just like stated above.... mud over the hole!
www.choptechfab.com
www.myspace.com/choptechfab
CHECK THE BUILD
KYOTA
what I did.
pull the cable out of the  case cut the threaded cap end off and epoxy a penny into the cap, reinstall cap when epoxy is dry
GreenYoterKrawler
Or do that broke A$$ cable right and leave it how it died Hahaha  :gap:
I blame the automatic transmission for the wussification of America
If Its got tits tires or electronics, your gonna have problems
I drive a jeep cuz toyota doesn't make strollers
