Author Topic: where to weld key stock on top shift t-case  (Read 1252 times)
yota-tota
  • Turtle Points: 17
  • Male Posts: 232
  • Member since Oct '05
  • Crawling over Marlin
« on: Feb 17, 2009, 02:31:52 AM »
I got my crawl box broken down to the point where you weld the key stock to the shifter ends. The thing is the pdf directions are for a forward shift case and i'm using a top shift one, which has the "slots" inside the reduction housing under the shifter....SOoo i'm unsure where to weld the key stock.  :dunno:Also on re-assembly of the crawl box would the drivers shift fork (looking from the rear output) be installed back on the modified main shaft? Like with the 3/16 roll pin/fork combo for the 2wd 4 wd selection?
91 toy truggy on h2 injection, hacked n chopped n locked n SAS'd rolling 36" IROKS........doubler comming soon
4RunnerChevy
  • Turtle Points: 5
  • Male Posts: 1,426
  • Member since Sep '08
  • Santa Cruz Mountains
    • Santa Cruz Wheelers
Re: where to weld key stock on top shift t-case
« Reply #1 on: Feb 17, 2009, 06:12:17 AM »
I advise getting the right directions.   :twocents:
yota-tota [OP]
  • Turtle Points: 17
  • Male Posts: 232
« Reply #2 on: Feb 17, 2009, 06:30:17 AM »
HA!! They're from the link in the tech section of the Marlin home page.
snowrun
  • Turtle Points: 143
  • Male Posts: 155
  • Member since Dec '03
« Reply #3 on: Feb 18, 2009, 06:18:57 AM »
Your front box is the low range portion of the tcase, you only need the hi/low shift rail & fork. Look at your shifter bottom, you basically need to weld the key stock so that the shifter will stay in place. I have had to slightly grind the end of the shifter tip that fits into that hole to get it to move freely
yota-tota [OP]
  • Turtle Points: 17
  • Male Posts: 232
« Reply #4 on: Feb 18, 2009, 01:36:35 PM »
Cool man thanks, I figured it out from looking at another sites install manual as well.
Last post Jan 05, 2006, 10:47:36 PM
by Jared
Last post May 26, 2006, 04:53:12 PM
by stanley02
Last post Jan 23, 2007, 01:25:14 PM
by Boheefus
Last post Mar 13, 2008, 07:08:57 PM
by kneedownnate
Last post May 25, 2008, 03:47:29 AM
by Bazzi
