Author Topic: Forward shift case, not a top shift like I thought...  (Read 1963 times)
snowplow
  • Male Posts: 257
  • Member since Aug '06
  • smoke tires not drugs
« on: May 24, 2008, 11:25:01 AM »
I am trying to figure out if Im screwed or not. I just pulled out my transfercase and am ready to put in marlin 4.7s. I thought my case was top shift for some reason, but it is forward shift. This case is going behind an adapted Ford NP435 Granny 4 speed so I wont have a transfercase shifter. (oh :pokinit:) I see an inspection plate where it looks like the shifter might go...
...so what now :dunno:
snowplow [OP]
  • Male Posts: 257
OK I just had a thought, I have another box on the bench with a marlin twinstick in it. If I pop off the inspection plate would my twinstick work there or is there adapters and such I will need?
Bazzi
  • Turtle Points: 97
  • Male Posts: 1,095
  • Member since May '04
  • From Reykjavik Iceland...
    • R&T
you have to get new/or modify your shifting rails. also the hole pattern for the forward shift shifter and top shift shifter isnīt the same. my :twocents:
 2,4 dti duals 2,28 x 2,28 to 8" 5.71 with arbīs  and 39,5" trxus
snowplow [OP]
  • Male Posts: 257
I can see where it says there is a forward to topshift conversion on the MC site but I cant bring anything up? Is there a different MC twinstick for a topshift and forward shift? I hope not because I cant remember if I had to specify but if I did then I probably have the wrong one!
Bazzi- 1. Bitchin Rig! 2. Do you plan on running the toy tcase with your 350?
Bazzi
  • Turtle Points: 97
  • Male Posts: 1,095
    • R&T
here īs a pic of the blockoff plate for the t-case
and here is a pic of the tailhosing block off plate.
you can see the difference in bolt pattern... I belive there is to kind of bases for the tvin shift.
I am planing to run the duals with the 350. I have a 23 spline input, a addapter plate from the 700auto .... I have a 4.7 23 spline  for the second case, and a heat treated output shaft.... I hope that will hold up...
Last post Aug 05, 2004, 09:09:38 PM
by Arapaho
Last post May 20, 2005, 12:05:51 PM
by Krazytoy
Last post Apr 15, 2008, 11:11:27 AM
by muddemon_06
Last post Apr 30, 2009, 09:54:36 AM
by Runar
Last post Aug 08, 2018, 12:18:22 PM
by helipilot77
