is it a 20R or 22R cylinder head?
Started by Toyoballs, September 21, 2004, 02:47:08 PM
Toyoballs
Can anyone tell me what year and if this is a 20R or 22R cylinder head?
Just Grind It Down To Metric...
"MAKE IT OR BREAK IT"
Extreme Off-Road Club
Mike D
Well it does have circle ports so it is most likely the 20r most of the 22re's have pear shaped ports.
brainlessfool
Toyoballs
Thanks guys, does anyone have a photo of a 20R head?
brainlessfool
If memry serives the 20r head has round intake ports.
and cast iron roaker arms.
Quote from: brainlessfool on September 21, 2004, 04:04:19 PM
yep  20R has round intake ports and exhaust ports, and uses cast iron rockers,   but i always swap them for 22 rockers
Marlin
#6
From your pics this is a '81-'82 [thick] head.
Square intake ports -- 22R
Round exhaust ports -- all '81-'84 22R
No dual carb, efi bolt pattern on intake mainafold side of head -- '81-'82.
'81 22R's had a double row timing chain with steel guides.
'82 22R's had a single row timing chain with nylon guides.
Which type of cam gear was on the cam shaft? This would give you the exact year.
Marlin
SWAMPER
Toyoballs
Quote from: Marlin on September 21, 2004, 07:24:18 PM
From your picts this is a '81-'82 [thick] head.
Marlin
Thanks Marlin...
Well from what I can remember (Allsimers @ age 42) it only had a single chain. I know I would have remembered it if it were double.
Hey Marlin, getting ready to install  one of your billet aluminum cases (borrowing from my buddy Scott) :disturbed: and I can't wait to do it. Just down loaded the new install instructions from, well, pirate back to this link.
thanks again Marlin
Marlin
Right on :thumbs: :thumbs: :thumbs:
From the factory, your head was 100 mm or 3.937 thick. If you have a micrometer, you can check to see how many times it has been surfaced.
Marlin
Marlin
Quote from: Marlin on September 23, 2004, 11:56:51 PM
Marlin
Why the heck is this guy so damn smart? :conf: :pokinit:
SWAMPER
Too bad it dint run in the family huh Mike :laugh:
JK :beerchug:
brainlessfool
 :laugh: yea brainless i cant believe lilswampy said that  :smack: i mean we were all thinking it but i cant believe he said it  :laugh:
awwwww we wuv ya anyway Mikey  :ladys-man:
hahaha you can all suck monkey balls  :talkingn:
Mike D
kyle_22r
i just picked up a motor out of an '82 celica and it has a dual row timing chain and steel rockers :dunno:
brainlessfool
SWAMPER
brainlessfool
Skinny_Pedal
there great salted and simmered in butter
Im an OG
brainlessfool
I'm thinking I'm more in the mood for raw and very freash.   :angry:
Just hang out with the guy in your avatar and your get some freash
brainlessfool
Swampy don't let me hang with him no more.   :down:
