no heat!!!
Started by ihanberg, September 20, 2004, 10:20:56 PM
ihanberg
i have an 85 4-runner with a 22re for whatever reason my heater isnt working so i took my dash apart and checked the heater core its fine and clean so i checked my ac box and it was full of crap after cleaning i reasymbled everything it now puts out luke warm air could it be my thermostat i have noticed that it runs cool about 1/4  on the guage my friend says his 4-runner runs about half way? any ideas? oh yea i also have one of those three row radiators.
Is your temp running normal?
ihanberg
it run cool according to the guage
BLUCRUZ
Make sure your heater valve is opening all the way, my cable from the hot cold lever broke and I didn't have a heater either.  If that is not the prop check your thermostat, it may be locked up in the open position. Radiator size shouldn't matter that much. When was the last time you flushed the system. It could just be plugged up too.
72 FJ40. 350 Multiport EFI, turbo 400, ORION T-case, 35 Procomp's  disk brakes front & rear, ARB's F&R and an onboard shower for the ladies!
86 sr-5 4runner SAS conversion. E-lockers F&R, 5.29's 4.7 Marlin case.
If its running cool, then you wont have any heat to begin with. Make sure its at least 1/4 gauge on your temp gauge, because your thermostat could be stuck open.
Remember that only Napa and Toyota carry the correct thermostat for yota's.  All the rest are garbage and will fail early and/or leave you with no heat.
ihanberg
i wemt and got a new thermostat from toyota and installed it today my 4-runner now runs at the appropriate temp a little under half it does put out a little more heat but not as much as my friends the heater core is hot to the touch so i assume its working! there is one other thing my fan speed only has one setting and thats high what could be causing this problem?
brainlessfool
If your fan only runs on high its the resistor thats in the airstream.  I have yet to find mine but I havent looked in about a year though.  You might have garbage built up in your heater core too.  Pull the lines off the heater core and flush back and forth with a hose till its only clear water coming out and Ill bet you have a better heater.
on my 79 the heater valve broke years ago,  i hook a small bungy to it and pull it over and hook to the brake booster,  nice and toasty, no bungy, slightly warm
and like wt said  switch :wave:
