A tundra diff could be put in a mini housing. The depth from the mounting flange to were the axles go into the diff is the same on the mini and the tundra-tacoma. It would be a matter of filling, drilling, and tapping the new bolt pattern. You would also have to push out the back of the housing to make room for the braces. A diamond would be easier but if you had time you could do it much cheaper.
I think it'd be easier to take a 8.4 rear housing and cut the tubes off and weld on the mini tube ends... then you would need to redrill, make the fron of the housing bigger.... blah blah blah.
Sorry to get everyone excited but I'm talking about the older tundra-tacoma diff that people refer to as the 8.4". I think this is a much stronger 3rd than the mini 8". It has a larger pinion, main bearings, and ring gear bolts. The best thing is the two trusses that go between the main caps. These make the 3rd more rigid and prevent ring gear defflection which is what kills most 8" 3rds.The bolt pattern for the housing is different and the bolts are bigger so this would have to be changed on the mini housing. The trusses take up space so the back of the housing would have to be enlarged. These diffs are strong enough that I think the axle shafts would be the weak point instead of the expensive 3rd member.
Yes for the rear this would be much better the info I posted is mainly for the front. I think the taco rear is 60.5" so you could run it as is without to much width difference.
I was not meaning to use it as a rear axle.I was meaning cutting the ends off a mini front axle and welding them onto the taco rear end... and making the tubes the correct length to match a 85 housing.
Maybe Oops could put a link to Pat's axle build thread. Sorry I'm e-tarded.
Here it is.http://www.pirate4x4.com/forum/showthread.php?t=654231&highlight=
Does anyone know if there are any diffs that the axle shafts fit into? Ford 9", Cruiser 9,5", Dana 60 diff or something. I have seen alot of guys running chromoly, marfields and Longfields, cromoly and Long shafts making the 8" diff the weak point. If there was a way to fit a bigger diff by simply clearancing the "cover" on the housing and drilling and tapping new stud holes and then stuffing the diff in there I think alot of people would do it. Not many people have access to a huge ass lathe or can justify the cost and hassle of an axle jig for one axle build. If one might be able to piece this together with OEM stuff found in wrecking yards, backyards and barns then many would try and we would soon find the best combination.So does anyone have a big diff laying around and a spare axleshaft? That might be the first step, if something fits then we might be able to forego the custom shafts for something OEM Toy, Ford , GM, Nissan or other.
Started by SEAN_at_TLT Parts Wanted
Started by rick80 Parts For Sale
Started by peacesells Parts For Sale
Started by mosebilt Parts For Sale
Started by toyotech Parts Wanted
