To straighten frame on get a new one
Started by freds40, September 15, 2004, 09:36:22 PM
freds40
  Let me start this by saying that before my last trip out, I had been planning to strip and rework the suspension and axles after the trip. So last time out, I bent my driver front frame. About 2 feet back from the front corner on the frame, there is a circular hole punched from the factory. That hole now has a decent bump on the bottom of it where the frame bent and bumped out. The driver front corner is now about 1.5" lower than it used to be. I can't really see spending the coin to take it to a shop to have it straightened.
  My thought on a home fix is to some how hold the frame with chain or a strong strap to the floor (maybe utilizing a snatch block for a downward pull), heat the bumped spot on the frame and lift the front corner with a high lift (or bottle jack for a bit more precision) until it "appears" to be correct. Another option is to find another first gen shortbed frame, swap all my crap to it, and then do all the mods I was planning to in the first place. Last option is to find a half way decent truck for cheap, swap all my stuff onto it (saving an engine/body swap), and then doing my mods to it.
  Give me some input. Would like to try the new setup in the snow before the season is over but I need a platform to build off of.
"between projects"
toyotaboy
just swap everything over to a bew frame.. itll take a full weekend.
rest in peace Effay
01 taco needs, duals, front axle, linked rear, exo...
85 extra cab/cab for sale with efi harness. no drivetrain, will sell, make offer
freds40
Know of anyone who has a first gen frame cheap? long or short doesn't matter because it'd loose a bit of frame either way.
"between projects"
toyotaboy
yep.. its sittin in my yard right now.. 83
rest in peace Effay
freds40
Looking to do this cheap. Don't need a new title. What you looking to get for it?
"between projects"
toyotaboy
$50... has 2" box tubing welded on for a body lift.
rest in peace Effay
freds40
Think it would fit inthe back of a shortbed Chevy for the trip to Fresno?
"between projects"
DAWGTOY
mine was bent in the same way only on the pass side.
used two backhoes (one to hold one to pull) and a torch.
pulled it right back where it should be. :bolt: :bolt:
not an easy task but it worked.
1983 TOY SHORT PICKUP .35/12.50S EXO CAGE HOMEMADE BED CAMO PAINT, REARS UP FRONT CHEVYS IN THE REAR, 4 WHEEL DISK, CABLE LOCKER REAR, LOCK RITE FRONT, 5.29GEARS FRONT & REAR.BOBBY LONG 30 SPLINES 9500 lb WARN WINCH. DUAL
T CASES WITH 4.7 IN THE REAR. THANKS MARLIN
toyotaboy
Quote from: freds40 on September 16, 2004, 06:20:18 AM
maybe.. ill get the demensions on it today and let you make that decision... probably will but will hang over a bit for sure..
rest in peace Effay
freds40
Yeah that's what I was thinking. Just with some quick numbers it looked like it will hang out a few feet. Any chance you'd meet me in Kettleman with it.  :eyebrow:
"between projects"
toyotaboy
not really... i am planning on going down to ventura this weekend to pick up a motor...
rest in peace Effay
toyotaboy
if you wnated to leave in the mornign and come over then we could probably do that b4 i left but i dont really want to drive to kettleman then back to where im at then to vetura and home...
rest in peace Effay
freds40
I have to work tomorrow. You be around Sat. morning?
"between projects"
toyotaboy
yep.. around 8-9 would be nice... dont want to get going to ventura too late.
rest in peace Effay
freds40
I'll have to check with the boss and see if I can get away Saturday morning.
"between projects"
freds40
Got a new frame!  :rockingout:  (thanks James) Let the mayhem begin.  :flamer:  :_order:  :shocking:
"between projects"
