FJ80 Ends / Jam Nuts
Started by Fireimp141, September 13, 2004, 05:58:07 PM
Fireimp141
Will these ends fit a 86 toyota 4runner front IFS?  :headscratch: i need to correct my alignment and want to do it the right way :thumbs:... also wondering if the pitman and idler arm on this site will fit the same thing, thanx alot
Marlin
Absolutly not :_order: :_order:
Ifs tie rod ends use a 17 x 1.50 mm thread.
Fj 80 ends are 23 x 1.50 mm.
Marlin
Fireimp141
Thanx alot, any suggestions on new pitman or idle arms and tie rod ends for an 86 yota runner ifs front?
Marlin
On the bright side, both tie rod ends use the same taper on the male tie rod stud. :thumbs:
This means that the FJ 80 tie rod ends would fit into the IFS steering arms.
Custom sleeves with jam nuts can be made for the center links.
Aftermarket braces are made for the idler arm.
Marlin
