89 extra cab
Started by 89sastoyo, January 24, 2009, 06:11:32 PM
89sastoyo
I'm currently building/rebuilding my 89 extra cab when I got it it had a broken axle shaft was driven with no bearing so i needed a new housing which i had laying around and some chromolly shafts so i just threw the third in it and started driving it.
heres a couple pictures of how it was when i got it.
some stuff i did to it was got 36 inch tsls made a stupid huge bumper that im currently fixing and baught a bobbed bed for a really good deal..
For the current stuff im putting in dual cases building sliders a front bumper eventually a rear bumper and a cross member for the duals.
89 extra cab stock on 1 tons.
92 2wd DD
first gen cab
Check out the build.
boggerunner
nice, gonna ditch the front inner fenders too?  are the stinger braces in the way of the headlights?
89sastoyo
u bolt flip and shock triangulation i didnt really like the outcome im sure when i paint the bed ill redo them they need to be much higher but the shocks arent the best so there temp bump stops:)
pulling the tranny and t case and getting ready for duals
92 2wd DD
first gen cab
89sastoyo
heres some of the sliders and bumper the bumper isnt finished though just tacked up with some scrap tubing for a rererance
92 2wd DD
first gen cab
89sastoyo
oh yeah and i got iroks:) traded the tsls and some cash flow for them heres the bumper and my stock cross member modded for the cases this isnt what im going to use its just for now why i work out all the bugs and get everything set up
shortening the driveline
92 2wd DD
first gen cab
89sastoyo
yeah taht stinger was just stupid from the beggining and those are hoaky fender flares cause i gotta ticket but to took them off the other night finished everything up or what i thought i got the driveline back everything was ready to be bolted up and then i got this wierd clunk feeling so i checked everything in the rear end because if it was only frotn wheel drive it was fine checked stuff out ended up being my third had 4 teeth broken and a few others damaged so while im waiting for the money to get the new gears and everything installed im doing to finish the bumper and work on bending up some tube for the rear bumper
92 2wd DD
first gen cab
boggerunner
that is the longest sentance ive ever seen.   what gears did it have?
86bobbedtoy
89sastoyo
It had 5.29s the bad part is i threw my friends welded third in it to go wheel at browns camp with some people then got lazy never put mine back in had his in it and it blew up.. The gears weren't set up profesionally so im screwed gotta pay for it and im stuck with a welded diff.
92 2wd DD
first gen cab
