Project GH Runner
Started by Ghtoyrunner, January 19, 2009, 06:41:33 PM
Ghtoyrunner
so i picked up a 1985 sr5 4runner last spring. i picked it up for 700 bucks. when i got it was in bad shape. the brakes were siezed to the rotors and it would barely run. so i started on the tune up right when i got it. i put all new brakes,cap,rotor,wire,plugs,tps,front end rebuild,alternator,belts,vacum lines. it was a good start for the project. so after all that it went pretty good. i wheeled it stock for about three months while i was gathering up the lift parts. it was black put i spray bombed it green. heres when i first got it.
When in doubt throttle out!
Ghtoyrunner
zome more photos on what it looked like when i got it.
Ghtoyrunner
heres some pics i snapped while doing the liftin the rear. i got f150s from a 2 wheel drive truck. and sky hanger kit. moved the axle back like 2 inches. only bad thing now is i need to get new one because u can see the splines :thumbdown: also i need to change the pinion angle becuase it doesnt look to pretty. got the stainless steel brake lines aswell.
Ghtoyrunner
some pics of the f150s.
