where i am starting
Started by 83yota, January 17, 2009, 08:22:25 PM
83yota
85 186K good order untouched except for the 4.7:1 kit tring to figure out the plans for it
boggerunner
u want clean, cheap or chopped and built?
86bobbedtoy
What direction do you want to go, what will it mostly be used for?
83yota
at first a daily driver maybe a 4" with 33s 4.88 gears locker rear for now. then in maybe 2-3 years i will do a small block swap 4 link coil overs something along those lines
Sheltonyota
Nice rig to start with , I want another 4rnnr esspesialy now that I have a girlfriend with three kids. Getting 84 or 85 is tough good job :clap2:
80 yota stock 4 now.   Future plans, alot of Marlin Products and a lot of work.
MiniSimp
I say leave it bone stock until you are ready. Fix up the motor and get everything cherry first. Then chop and swap.
83yota
i am still strongly leaning towards the chevys in the rear rears up front. and a set of 33's and a good header and exhaust
83yota
well what should i name it? chota was my last truck but what should i name this one
83yota
#9
ok so i worked on some drawings for the runner. PLEASE remember i am by no means an artist. and due to this theme how does WHEELYS sound?
all the emblems will be in flat black and the truck and wheels will be in OD green
83yota
so i was talking to a buddy and he said run chevys in the rear and wagoneers up ft is this right? if so ft or back springs? do i need to remove any of the springs from the pack?
83yota
well i just had a guy give me a set of 62" chevys and a 4" allpro ft kit is this a good thing to run?
Talon84x4
Sounds good to me, depending on the chevy's you might need some longer shackles on the rear to match the 4" front springs up front
Low & Slow 84 PU - http://board.marlincrawler.com/index.php?topic=31982.0
Central Valley Crawlers
83yota
do i need to pull any springs out of the back pack for flex? i still need good road manners
porkchop
Quote from: 83yota on January 22, 2009, 09:02:53 PM
no do not pull no springs out of the chevys, are you sure they are not 63"
85 TRUCK AUSSIE IN FRONT LINCON AROUND BACK MARLIN 4" SPRINGS UP FRONT WITH 63 CHEVYS ON BACK. REBUILT 22R WITH CRAWL CAM AND FEW OTHER THINGS NOTHING HUGE JUST WAITING TO GET PROPANE ON IT. RUNNIN 35'S M/T WITH MY LONGFIELDS 30 SPLINE SUPER AXLES. 4.7's IN T-CASE AND ON THE WAY WITH DUAL CASES. FULL HYDRO WITH TG ROCK ASSULT PUMP AND 2 X 6 AG RAM
oldyeller
83yota
thanks your right hit the wrong button. how much lift will the chevys give?
86bobbedtoy
62s or 63s ?
63s are from the older chevys 3 main leafs
and the 62s are from newer ones 2 main leafs
here's my truck with F150 rear springs and 5 inch Allpro fronts
porkchop
here is mine on 63's with 4" Marlins on front
83yota
did you do a hanger change? i was thinking the 2 sackel sets together
88_Pathy
Porkchop, why does it appear that your front springs are backwards?
83yota
