single t-case crossmember
Started by sweetmeat, January 05, 2009, 09:12:01 PM
sweetmeat
i am having issues with my crossmember. i was wondering if i can use a turtle shell crossmember with a single t-case or will my rear driveline hit it. i suppose i can always cut it out. any ideas on a good crossmember setup for a single t-case?
A&G Motorsports Class 1 #1553 Crew Member
Wrecked4x4.com
FLRunner
sweetmeat
the issue i am having is that where the crossmember actually bolts to frame. all of the threaded holes are actually stripped out. and the tabs for the 4 outer holes are actually peeling from the frame. the budbuilt crossmember uses these same mounting holes as the stock 1 and so does the turtle shell as well as others. i did find 1 from a company called 4x innovations that is actually a tube style crossmember that uses a totally different mounting base. it bolts to the frame but in a different location. though i have never heard of this company, and am not sure how the actual fit is. is there anybody out there that has 1 or know anybody that does. or any other suggestions :help:
Wrecked4x4.com
4RunnerChevy
You can put threaded inserts into your stripped out holes (helicoil) and actually make the holes stronger.
sweetmeat
yea thats always an option. what about a turtle shell? all my buddys run them they work great. i should be able to use it if i just trim it a little right? since my rear driveline is longer using only a single t-case?
Wrecked4x4.com
Weld some old front end u-bolts to the frame.
4RunnerChevy
Quote from: sweetmeat on January 07, 2009, 07:18:00 PM
I dunno, I just made my own.  I welded feet to the frame and made the crossmember bolt to that.
Early pic when it was being fabbed.
Installed, sorry only two current pics I have.
sweetmeat
that looks like it worked out pretty good. thats always an option
Wrecked4x4.com
