bead lock ring torque
Started by 79 turd, January 03, 2009, 03:39:34 PM
79 turd
I was wondering if anyone knows the torque spec for a walker evans bead lock ring?
Homefries
I'm guessing about 5 - 10 ft/lbs and tighten them in a star like pattern.  If you tighten them to tight it makes the bead lock ring bow inside and you don't get a very good seal.
BirdDog
The instructions on my Champion Bead locks says:
10 FT/LB for 1/4" Diameter Bolts or
15 FT/LB for 5/16" Diameter Bolts
Here is their website with instructions:
http://www.cwibeadlock.com/mountinginstructions.htm
79 turd
I will look and see what size they are and give it a try thanks for the help.
