T case questions
Started by ElkoToy, January 02, 2009, 09:52:53 AM
ElkoToy
I am building my first project and i am going to run a 22RE two T cases and 37's. I want to keep it as drivable as possible will 4.88's work?
KYOTA
yep and stronger. hell I'm still 4.88 on 40's  :talkingn:
ElkoToy
Thank you. I am sure I will have a million more before this thing is done.
KYOTA
right on, post up your progress. you can edit and re-name your thread at any time if you want and welcome to MBB  :beer:
i would say 5.29's  why make the 22re work harder than it has too :dunno:
4.88's are stronger.  you won't see very much of a difference in performance between the two either.
bigarms23
FLRunner
i have a 22re   and i run 36 iroks  with 4.88  its a dd  I  drive it 200 plus miles a day   But it rarely sees 5 th gear     about 75 mph its at 3200 rpms  in 4th  .   I would suggest 5.29  if its a dd    that is what i want to swap to .
Slolyfe
Im running 5.29s with 37s and a really hopped up 22r and it is balanced pretty well. about 75mph at 3000 rpm in 5th and ive never broken a r&p
You'll never take me alive
5.29's would be a better gearing choice, but 4.88's a much stronger. I would make my choice on how hard I'm going to beat on them. I am usually easy on my junk so I'd go with 5.29's. If you are a little hard on the skinny 4.88's would be best.
ElkoToy
I have a turbo tranny and T case 23 spline and one T case that is a 21 spline when I buy a 23 spline 4.7 to 1 gear kit will that have every thing I need to change the 21 spline to a 23 spline or is there more to buy? And can someone give me the low down on puttig pictures on?
ElkoToy
OK more questions my donor truck for my motor is a 93 or 94 toy 2wd with a 22re. When I rebuild the motor what are some thing that i should do to it?
ElkoToy
Here are some pics of where i am at in my project.
I put a 87 extended cab on my early 80s frame.
