t case noise going from load to deceleration
Started by Mrblue, December 17, 2008, 09:58:52 PM
Mrblue
I have a turbo trans w/ dual cases and stock gears. In 4 hi I'm getting a rattle type noise only happens between load  and deceleration. Both drivelines have cv's and are in good shape. Where should I start troubleshooting?
Thanks in advance for any input, Brent
ZUK
Quote from: Mrblue on December 17, 2008, 09:58:52 PM
I tend to think you're in transfercase hell...I friend had a 2nd case installed in his daily driver and he had the same loud rattle...NO other changes were made during this upgrade so we figured it must have been the case so he had it replaced with another and the same thing. It was a noise that would have driven me nuts if it was in my dual case but mine was quiet so thank God for that.  I wonder if it has more to do with the coupler between the 2 cases.
           www.gearinstalls.com
2001 White Xtracab Taco 3.4L Auto TRD
88 Runner/V6/auto/31"/5.29gear
Cheesemaker
Mrblue
Yes it's a marlin completely assembled  23 spline reduction box and a stock turbo t case. It's the first time i have used 4 hi range since the box was installed usually go straight to lo range.
Birfailed
Put a bottle of Lucas in it.  The whole thing.   :boozer:
Go 1-Ton from the start
mine did that when i first put them in, then the noise went away so am happy.
Did you replace any bearings in the tranny?  A bad input/output bearing can make a similar noise, and the duals may just amplify it.
88_Pathy
Mine does it too. It is normal. Marlin said so himself, I had him ride with me.
Mrblue
No new tranny bearings. the noise is getting louder the more its driven. sure sounds like its coming from inside the t case not the crawler box. Got a mechanics stethascope gonna try to isolate where its coming from, with my girl drivin so I can poke around .
That's a good idea.  As has been said, marlin will make it right if it's an issue with their parts, but if not they'll still do what they can to help you out.
White 92
Mr Blue did you figure out the grinding/growling noise? I'm running an 86 turbo trans 228 crawl box 4.7 in back with the exact same problem. Only happens in 4wd.
RUGER
dr blue has not been active on the board since 2010. you can use other responces to this thread and hope it fixes yer issue.
RUGER :usa:
:usa: GOD BLESS AMERICA :usa:
"the hag" 83 toy with 5" all-pro lift, marlin crawler dual case #1011 and marlin hy-steer, 35s, 5.29's, exo cage, yada, yada, yada. she's back in black.
97 F250
84 Grand Waggy
77 Scout II SS
96 Explorer Sport
20 F150
USN SEABEE 2008-2012 :usa:
run with THE PACK 4wdc of los osos
NRA life member
are you a traveling man   SMIB
