Author Topic: 82 22r oil geyser  (Read 1323 times)
82.1st.gen
  • Turtle Points: 37
  • Male Posts: 52
  • Member since Jul '08
82 22r oil geyser
« on: Dec 14, 2008, 12:36:50 PM »
so i was going to the snow and i was messing around in two wheel drive getting my rpms up and the next thing i know i have oil shooting out the top of my valve cover where that line goes back to the air cleaner not the pvc valve. so my question is what the hell is causing all this blow by. the head is brand new with at most 700 miles and the bottom end has around 200k. please help!!!  :dunno: geyser
1992 Toyota 4x4 sr5 auto/3.0 swapped to r150f 5 speed and 3.0 swapped for 02 3.4!
tech201
  • Male Posts: 141
  • Member since Jan '08
  • this is who we are this is what we do.
Re: 82 22r oil geyser
« Reply #1 on: Dec 14, 2008, 01:43:32 PM »
usually blow by that bad is caused by the rings being worn out (engine needs rebuilt) but you might want to check the pcv valve make sure its working.
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
« Reply #2 on: Dec 14, 2008, 02:20:06 PM »
i think you answered your own question,  did you check piston - cylinder clearance when you had the head off?? did you do a compression check before replacing the head??
dt
  • Turtle Points: -107
  • Member since Oct '07
« Reply #3 on: Dec 15, 2008, 11:30:54 PM »
plus sometimes a new head makes the old rings wear out even quicker
Caboose
  • Turtle Points: 62
  • Male Posts: 733
  • Member since Jan '05
  • Truth... Justice... Honor...
« Reply #4 on: Dec 16, 2008, 12:10:08 AM »
just rebuilt the motor, ull b happy u did it.  i am.  Im not happy i spent 250 rebuilding the carb instead of spending 300 to convert it to EFI =(
"Who let the jeeps come?
Easy... easy..." -2 people on the CB
81 Toy Pickup SR5
http://board.marlincrawler.com/index.php?topic=35701.0
Daily Driver: 96 Dodge Ram 2nd DD/Tow Rig
Plekto
  • Turtle Points: 27
  • Male Posts: 863
  • Member since Aug '07
« Reply #5 on: Dec 16, 2008, 04:07:26 PM »
Yeah - high revs in an old motor plus loads of oil all over the place usually means you blew a chunk of a ring from the stress and everything's taking the easy way out...(instead of slow blow-by which most of these old trucks get over time)  I'd have also suggested a gasket or valves, but 700 miles is too new unless you literally just about put it in backwards.
Last post Mar 26, 2015, 08:45:59 AM
by BigMike
