Author Topic: HELP!!! 1980 20r 2 new voltage regulators and 2 new alternators  (Read 2769 times)
crackdaddy
  • Member since Jun '08
HELP!!! 1980 20r 2 new voltage regulators and 2 new alternators and its still over charging 18 volts  :dunno:      what next
  • Turtle Points: 1452
  • Male Posts: 22,633
  • Solid axle Toys Rule ! ! !
replaced both at the same time??
does the new voltage reg have the clear plastic cover over the harness plug ??  if not its for a 2wd
crackdaddy [OP]
no its green . all i know its a 5 pin plug
ok, the PLUG itself is green but the 4wd version has a clear soft plastic (condom type thing) over the plug
probably doesnt matter but its NOT working right so :dunno:
where did you get these alts, and regulators??   autozone??  :ack:  they are notorious for selling bad alternators that have just been cleaned up
but if it IS charging 18 volts, perhaps the battery is  really dead ?
crackdaddy [OP]
tryed a diff battery and the same thing 18 volts . and no not from autozone . the first alt i got was not charging at all now the new one is over charging thats y i thought it was the regulator????
yoter4x4
  • Turtle Points: 31
  • Member since Dec '08
  • Team Bungie!
would a voltage regulator that's going bad cause the motor to die when you pull a cable off the battery? and also make the truck miss while it's running? it has a new alternator from napa and a rewired alternator harness. battery is always fully charged.
i thought it was my carburetor so i swapped carburetors and it still runs like it needs to be tuned really bad. than someone mentioned voltage regulator. help PLEASE
Bullets don't know the difference between race, sex, or gender.. They Just Feed On Flesh!
as i told the OP 2 years ago,
Always replace both the regulator and alt at the same time
and to the question of "will pulling the batt cable off make it die if its not working??"
  YES
yoter4x4
  • Turtle Points: 31
  • Team Bungie!
a buddy that works at the import junkyard in town gave me a free regulator today. the truck runs perfect again with the new regulator. damn oval plugs on them cost almost $100!!!!!!!!!!
Last post Feb 28, 2008, 02:35:58 PM
by calitaco
Last post Aug 23, 2008, 09:51:45 PM
by i_luv_my_truck
Last post Nov 14, 2019, 01:30:38 AM
by Slabzilla
Last post Feb 23, 2020, 07:01:50 PM
by idahank
Last post Apr 12, 2020, 11:43:25 PM
by Rocksurfer
