Toy tranny
Started by Bonejoe18, August 27, 2004, 05:31:38 AM
Bonejoe18
I am running a Toy drivetrain in my zuk buggy and I have everything but the tranny and T-case, I want to run an auto tranny in it,what tranny and T-case would this be and how strong are they.
Marlin
If you chose to run a Toyota auto, because they are electronic and tied in with the engine, you must have a complete setup including the engine EFI and auto trans computer.
They have had a good service record.
Marlin
UNBREAKABLE
I have one of the auto tranny's. A340H. P.M. if interested
That's how I roll
