Transmission Gear DAMAGE HELP!!!
Started by zippo, November 23, 2008, 02:27:18 PM
zippo
So I am in the process of disassembling/rebuilding my 1988 W56B with 250,000 Miles. I get it all apart and notice some damamge to the fron input shaft gear. I am not the best on transmission gears and don't know if it is still good to go or if it need to be replaced. Where would i find one without buying a hole transmission, that would defeat the point of the rebuild. Marlin? How much would it be also? Thanks for you input, HELP!!!
If you see it, its for sale.
emsvitil
On the edge like that you'll be fine.......... (there's no tooth to tooth contact there)
Just dremel the chips smooth so there's no stress risers.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
zippo
I have also noticed 4 other teeth next to the broken one with stress cracks, will that also be ok to just dremel? Or should I be more worried? Blah why am I always so nervious when its my own stuff!!! :-p
i wouldn't use that,   call Marlin tomorrow, they might have something to help you
highridin4x4
I would also clean it up and use it again. When I did mine I could only get a new price from toyota I think it was like $400.00 No one wanted to sell just a used input gear out of there rebuildable trannys.
Scott
emsvitil
I'd dremel those too.
Take it down far enough so that the cracks are gone.     Use the little sand paper wheel (about 1" diameter).
You can go about 1/4" in on the teeth.   Look for the wear pattern and see where it ends.
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
emsvitil
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
emsvitil
#7
Here you go:
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
zippo
So I started to clean the cracks up and ended up with this. It appears the damage extends into the gear face/wear pattern? Damnit?
zippo
So i called around "including Marlin" and noone sells just the input shaft. I called the dealer ship and it is a rare part at 450 $$. I thin called Nix99 and bought a whole used W56B core for 250. Hey, nothing wrong with exrta parts!!!. Never had a problem money couldn't fix...
emsvitil
That's about as far as I would go for dremeling; but I'd have dremeled it, and called it good.........
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
emsvitil
Let me guess, your input shaft bearing was trashed...........
Ed
SoCal
86 SR5 XtraCab
22RE  W56B
31x10.50R15
Plekto
That's fine, really.  The problem is if something in the middle(where the notches are) is messed up.  As it is, a little space will be there between the two ends of the gears.
RN37DD
hmm. be carefull with your core. it looks like that gear may have been damaged when an input bearing was removed. don't use anything real hard against Toyota gears. some Toyota gears have raised metal on the side of the teeth and the well chip when you use something hard to press them on or off. make a spacer or use something like aluminum. i made some aluminum plate spacers so i wouldn't chip anymore gears.  check all your gears and good luck.
i say it would have been good... as lonmg as your core ones are even better though... you should be fine, hel, i say rebuild yourself a spare tranny with the bad gears that aren't that bad.....
94MtnYote
 a replacement gear is a good peice of mind. there could be micro cracking extending further down thats imposible to see without red dye spotcheck or x rays.  best of luck to ya!  :beer:
Marlin 1200LB clutch
