then you cant use it on your 22re and keep the egr system
be aware, it is possible to remove the system, but if you live in CA or other places that emission test, you will not pass
you could potentially drill holes and tap threads in the flange for the injection tubes, and then jsut use a gasket from the pear port exhuasts
