22R and 22RE header the same?
Started by Volcom, April 06, 2006, 02:18:06 PM
Volcom
Dumb question but will a header for a 22R fit the 22RE?  After looking at the stock exhaust manifold for my 22RE, it's cracked and been welded.  I can get a header for a 22R for cheap.
Thanks!  :turtle:
84 4Runner
Marlin Dual Ultimate crawler
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
FIREBALL
I'm not positive, but I think the exhaust ports are a differant shape.
4inchToyotas
Ports should be the same it's the EGR and O2 bung that you gotta make sure it has, some 22r headers have EGR some don't (depending on who's header and what year they're for etc)
2006 Tundra DC 4x4 - DD/Tow (if I can ever find a place to store a trailer)
1983 Hilux - 20/22r Weber 32/36 carb, 4" ProComp suspension, 5.29's Lockrite Front, Spool rear, 34x10.50x15 LTBs
22R's  had a round exhaust port  with a small port above for the egr,  most headers block this off,  on a efi  you will need this port for the o2 sensors to work right i think
the 22RE  has pear shaped ports
89 toy
 22r's have pear shaped ports also. i just took a 86 22r apart today and it has pear shaped ports. 89 and later 22re's have the o2 sensor in the exhaust not the manifold itself. if the header blocks the egr ports just drill them out.
#5
Quote from: 89 toy on April 06, 2006, 10:41:40 PM
i think 85  is the year they started the pear shaped ports,   my 86 22R  has them
Volcom
So I take it's more hassle than it's worth  :greengrin:
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
glen, there are 2 versions of the 22r... the early version and later version, the later version was 85+ and had the same pear ports as the 22re, however the earlier 22r had round ports
my 85 22r has pear ports, both engines of mine
Volcom
84 4Runner
Marlin high steer
TG springs
109" wheelbase
Addicted Off Road
Quote from: jimbo74 on April 07, 2006, 11:31:50 AM
::)  duh
Quote from: 79Coyotefrg on April 07, 2006, 12:15:36 PM
::)  duh
um you were the one who said the pear ports started in 86, they didnt, they started with version2 of the 22r which was the 85 and later version, which had the same ports as the 22re
89 toy
i dont think it is a year thing a buddy of mine has a 87 22r and it has round ports a nother friend of mine has a 86 22r with round ports and i have a 22r head of a 85 and it has pear shaped ports.
crawlerdan
I HAVE A 22R HEADER ON MY 22RE...ONLY DIFFERANCE IS EGR PORTS AND LOCATION OF O2 SENSORS...LIKE YOU REALLY CARE...IF YOU WANT CONFIRMATION, GO TO YOUR LOCAL PARTS HOUSE AND ASK FOE A GASKET FOR EACH, COMPARE THE TWO...AND WALA...THEY ARE EXACTLY THE FREAKIN SAME, THATS WHATY I DID :thumbs:
olemisstoy88
I have a stock header with a downpipe for cheap from a 22re of an 88. if you want it LMK
88. 4x2  Total chaos 6.5" caddy uniball kit  Racerunner 2.5 x 14" coilovers on front, 62" deavers, fabbed engine/shock cage, bed cage, roll cage and great frame, complete int., (5) 5x4.5 outlaw II w/235 buckshots <----- parting out! make offer
'84 4x4 . 5 speed 22r  3.5" lift  33x10.5s bfg MTs  Hannamann Glass frontcap, 32/36weber, LCE swirlie plate, Magnaflow,
"Im madder than Toby Keith at a Dixie Chicks concert"
