Master Cylinder Suggestions
Started by blackdiamond, November 17, 2008, 08:04:31 PM
blackdiamond
1989 Toyota 4Runner
What master cylinder should I get and why?  Mine is leaking after yesterdays rear brake job and complete fluid swap.  The old fluid was nasty black and I think the new Dot 3/4 synthetic fluid pushed the old master cylinder past the breaking point (pun intended).
blackdiamond
Quote from: 88_Pathy on November 17, 2008, 08:34:29 PM
Get the one from here. http://www.marlincrawler.com/htm/brakes/mcylinder.htm
Certainly an option, but I would prefer to not mess with the existing hard lines and my 89 has an equal capacity unit.
Duffil
if you already have a 1" bore cylinder, stick with that. You can't get any more power without going to a unit from some other vehicle. (GM, Mustang SVO, etc.)
Joey88RUNR
I do NOT recommend buying AUTOZONE's i had mine replaced under warranty 3 times..untill i finally upgraded it to a V6 master cyl :twocents:
Rockcrawlintoy
im goin with the GM one from rockstomper when i need one
Resident Jeep Guy
2007 JKU All Stock
ECV 7-11
printthis
A Toyota one ton AISIN 1 1/16 bore from carquest. It bolts right in, supper firm pedal. I can lock up my 37 toyo's
where a Tacoma 1" bore would not with my rear disk set up. But a Tacoma with a stock system works good.
Birfailed
I got the one from rockstomper along with the dual diaphragm booster with my 60 front and 14 bolt rear with discs, can lock up aired down 38's at 30 mph and stop in about 12 feet...it's pretty damn violent, you get thrown onto the dash.
Go 1-Ton from the start
Cheesemaker
Quote from: printthis on November 19, 2008, 05:56:51 PM
By any chance you got the part # for this?
blackdiamond
Are they both direct bolt in applications?  Do the hard lines need to be modified?  Any particular year of Tacoma?  Do you know what the application for the AISIN 1-1/16 unit is?
The one I have currently (purchased yesterday) is for the 84-early 89 application, but is the same part number as the 89+.  It is officially manufactured by United, but says AISIN on the housing.  It has some number that make me think it is a 13/16 bore, but I thought it was going to be a 1 inch bore.  Does the V6 models use a different master cylinder?  I may see about getting the Tacoma application since there isn't a Carquest in the area.
ajordan1975
blackdiamond
The replacement master cylinder I got for 88 4cyl is a 13/16 inch bore.  I called the part store and the V6 application is a 15/16 inch bore.  I would like to upgrade as much as possible.
What mods are required to run the 1 inch Tacoma master cylinder or does anyone know the year range for the FJ-80 one Marlin sells?  I need to get the part locally since I want to do the install on Sunday and get the 4Runner back on the road.
get brand new FJ80 MC from NAPA for 80 bucks.
the hardlines go right into it. you may have to pull on the lines a little.
I run a 93 T100 Booster and 95 FJ80 MC and my stock 87 lines ran fine to it.
and it will run fine in my 85.
:thumbs:
blackdiamond
Quote from: 85HOrunner on November 20, 2008, 06:41:47 PM
:thumbs:
I have a 95 Landcruiser MC on order that should arrive in time for the install.
Score :P
you have to swap your resi over to the MC.
blackdiamond
Quote from: blackdiamond on November 20, 2008, 07:53:47 PM
cover?
i think he is asking about the actual clear plastic reservoir, some MCs dont come with that
the only mod to the hard line which are actually quite soft,  you just gently bend it to fit,  dont bend it all in one spot,  look at the bends already in the line, they look to have used a 2 inch diameter bender, i used my left hand
or loosen it at he "T" fitting and rotate it and you barelyt bend it over... just barely. :D
and yes the clear plastic resivoir hat holds the fluid, sensor and cap. :D
Here is my T100 Booster with 95 FJ80 MC and a 94 4Runner Resi
yota_krawler
I am running a 15/16ths MC and I can tell a big difference between the 13 and the 15 sixteenths, however I would like more!
The Supra has an even bigger MC then the FJ80
like 1 1/8in bore I think.
blackdiamond
Quote from: 85HOrunner on November 21, 2008, 10:37:01 AM
Hmm, I was looking for the Celica instead of the Supra and it was only 15/16 which makes sense.
I ended up installing the stock 13/16 MC because I couldn't swap the reservoir over and couldn't get a new one yesterday.  It was sad, but at least I got an AISIN unit and my brakes are back working properly again.
those 35s will wear that MC out before too long... but least you have brakes :P
printthis
Sorry for so late :dunno: Part# 20-2710 fits 93-99 T100
printthis
Just the Master Brake Cylinder. the Booster to use is from a Tacoma it is a little longer, a little smaller around and has 2 diaphragms
Quote from: printthis on December 30, 2008, 02:46:33 PM
oh really?
the T100/3.0V6/22RTE has the dual diaphram booster as well.
a little larger in diameter then the 79-88 4cyl Boosters.
I run a 95 T100 Booster with a 95 FJ80 MC.
fits perfect and no clearance issues.
is this the booster you are referring to?
printthis
The Tacoma 2X4 or 4X4 is smaller around so if you have lots of crap under the hood there is more room. I have a hole collection of stuff and still need to run a cold air intake on mine.
Quote from: blackdiamond on November 24, 2008, 12:05:22 PM
I got my 1" mc out of an 87 supra, and every similar supra had the same 1", as did the celicas from the same era.
