wheel base short? or long?
Started by 1983bamayota, November 15, 2008, 12:11:16 AM
RCKSQRL
mine is about 107 with 37's, we have a lot of tight trails here in Idaho and I think it is about as long as I would want to go here. Still climbs great and don't get high centered.
'85 EFI Runner
4.3 with 700R4- for sale
5.29 detroit F/R
Front 3 Link with air shocks
rear 4 Link
Custom Fuel cell
8274
Crawler #719, rear with 4.70 # 677,
Twin stick
Skys manufacturing T-case crossmember
6 point cage modified with harness bar, dash bar and PRP seats mounted to cage
2 feet chopped off the back
It seems it is never done........
in works for new body and exo, motor and trans swap...
Quote from: RCKSQRL on January 06, 2009, 08:23:52 AM
EXACTLY! our trails in Idaho are very tight.
I think any longer then 108" and you're way too long.
yota_krawler
build it for california trails lol
LWB!
Ghtoyrunner
my wheel base on my 4runner is 111. it has good angles for what im doing. climb alot of ledges and steep down hills where i think the wheelbase makes it more stable. i would like to get it around 115 but i would need to get a longer rear drive shaft. the only down side is i find my slef doing like a 20 piont turn on those sharp corners wich sucks.
When in doubt throttle out!
twistedtoy92
After my SAS the 92's wheelbase came out to be 112'' .....stretched her 11.5 inches :yupyup:
