89 sas reg cab 22re 2800.00 as it sits BEFORE DEC 3rd pics added
Started by BoG-ToY, November 12, 2008, 07:43:41 PM
BoG-ToY
I will go 3200 for JUST THE TRUCK RUNNING DRIVING THE WAY IT SITS
need money, so here goes, its in redding ca,
22re with approx 40k miles on it, built it myself, moly rings SS valves, and everything else new, a mild cam,
clutch and flywheel with 10k on it
4.7 TG case with 10k on it
decent tranny with unknown mileage BUT synchros kinda suck, but otherwise all sounds good
TG steering arms
SKY pitman adapter
three marlin rod ends, marlin tie rod and tg drag link
tg knuckle kit,
tg axle armor including small diff guard, axle truss, kreeper ball gussets
longs chrome IFS to SFA lockouts (chromo rings in IFS lockouts but uses factory c-clip)
85 front axle stock birfs and such
5.29 open up front,
ZUK replaced my bearing in my rear third AFTER I installed my gears and lockright, cryod bearings and zuks approval on gear setup, he reset the pinion and carrier preloads but left the patteren the same... kinda deep on the ring but runnable
has some bald dunlop 315x75x16 on stock taco alloys with lugnuts
when my stuff gets here, I will have a  9.5I   some good 35x16x15 boggers, a bad tranny and a good tcase that needs some heli coils in the reduction housing
spare v-6 open diff,  supra lsd and 5.29 yukons coming with my stuff
$4000.00 OBO any cash offers will be considered.....
Sand, what fun, drop pressure to 12psi, stock tires are still digging, can't afford to get stuck, 8psi, still not working. Find a place to GET OUT, air up, un-lock hubs,  WAIT whats this, hubs are UN-LOCKED already. 2wd, 8psi, stock tires, Oregon sand dunes.
BoG-ToY
http://board.marlincrawler.com/index.php?topic=38853.30
pictures of it before the operation to drive home..... its not as tall and not so aggressive of tires right now.
have ALL the parts still that made it look like that and will include for the full price.....
ALSO have TWO perfect 2wd doors in a blue color (only the one door mounted mirror on the drivers side, no window mount mirror, but in perfect shape) and a sliding rear window
ToYocRawleR
How does the motor run?  Does it have pretty good power?
thanks
Rigs:
05 F-250 Powerstroke
93 RunneR ...Build-up  http://board.marlincrawler.com/index.php?topic=85644.0
fortysixandtwo - I drove through Dunsmuir once I dont think anything there is "super nice"
Just kidding man. I guess there is, its your bed
BoG-ToY
motor runs great.... will burn both rear tires if you do it right.
I built the motor myself....and did everything PERFECT..... all my specs were right in there center to tight range  did it perfect....
Im pretty sure it will smog no problems...if Ive got someone with the cash on the table to go smog it I will, nothings changed since the last smog....except the engine has 40k miles rather then TWO, yeah... it smogged two miles after I fired up the engine..... tells you it must have been built right... it took about 30 seconds to break in
be happy to show it to you, let you check it out... and maybe go check out the 4x4...
ToYocRawleR
Does it drive good?  You say you still have the 35's or not?
Rigs:
BoG-ToY
right now its got 315x75x15
35x16x15 boggers are still in a moving truck but will include if someone will pay me the 4k.... I need the money and need out of the truck... same thing with  spare tranny tcase and winch...all on a moving truck
BoG-ToY
I think it drives good... just drove it from florida to here.... do you want to test drive it???
ToYocRawleR
Im just kickin the tires right now.  Its what im lookin for, do you have any other pics of it?  More of the fab work?
thanks
Rigs:
BoG-ToY
ToYocRawleR
Rigs:
ToYocRawleR
Im only 1.5hrs from you and i have a couple buddies that live in redding so if i decided to look at it i could head up your way no prob.
Rigs:
BoG-ToY
bump...... new offer till the first, but, if I defualt on my credit cards I probably wont sell that cheap... just trying to get the money to pay my bills
BoG-ToY
