Author Topic: Gear driven t case behind a V6  (Read 2984 times)
blackyoter416
  • Male Posts: 43
  • Member since Oct '08
« on: Oct 24, 2008, 07:54:06 PM »
I was wondering if someone could tell me what all i need to put  a gear driven transfer case behind my v6 tranny. i know i need the t case obviously n the adapter plate, but is that it???
how hard is this swap??
90 std cab, 3.slow, short box bobbed 12", 85 front, hi-steer, hi-pinion, 529s, locked, 39.5 iroks, 5" marlin springs, bilsteins...
  • Turtle Points: 2872
  • Male Posts: 8,707
  • Member since Sep '05
Re: Gear driven t case behind a V6
« Reply #1 on: Oct 24, 2008, 08:03:47 PM »
i think it is as easy as adding the adapter and a top shift gear drive transfer case behind it, you will also then need to modify the length of your driveshafts
blackyoter416 [OP]
  • Male Posts: 43
« Reply #2 on: Oct 24, 2008, 08:06:42 PM »
new driveshafts? im not doing a doubler, just tossing the chain driven and putting in a gear driven
  • Male Posts: 8,707
« Reply #3 on: Oct 24, 2008, 08:10:53 PM »
ah, ok, i just assumed you wanted a dual case setup, thats why going to a gear drive
this should help out
http://www.marlincrawler.com/htm/transfercase/v6_plate_instal.html
dirtchicken
  • Turtle Points: -44
  • Member since Nov '06
« Reply #4 on: Oct 25, 2008, 04:04:41 PM »
You will need the V6 adapter plate and a gear drive t case mount. No driveshaft mods should be necessary. For the mount I went with one from 4xinnovation. It's cheaper than Marlins and it is BOMBPROOF.http://www.4xinnovations.com/pages/drive/casemount.htm
blackyoter416 [OP]
  • Male Posts: 43
« Reply #5 on: Oct 25, 2008, 07:37:08 PM »
thanks, thats what i needed to know
and when i buy the 4.7 gears for it, do i buy the 21 or 23 spline??
OOPS
  • Turtle Points: 1304
  • Male Posts: 2,561
« Reply #6 on: Oct 25, 2008, 08:59:22 PM »
23
MaXXis85
« Reply #7 on: Nov 11, 2008, 07:56:38 AM »
Well this brings a question to mind. If i were to do this swap in my 89 extra-cab, I would not have to modify my driveshafts? I currently have a V6 chain drive case like the Original Poster, and also want lower gearing. I do plan on adding a doubler but this simple mod could make alot of V6 people happy for now , then add a crawlbox later when needed.
I guess the main question is this. Is a chain drive case the same length from Trans mating surface to rear t case output flange the same as a chain driven case? If no one can tell me this I have an Extra cab V6 chain drive case with a stock 2 peice rear shaft, and my brother has a 4 cyl extra cab with a gear driven case and stock 2 peice rear shaft. I guess i can measure both cases to give a comparison.
I am really hoping this is a quick mod becase i can get this case geared lower and twin sticked, then throw in a crawl box for the ultimate setup later.
If anyone has these measurements handy they would be appreciated.
MaXXis85
« Reply #8 on: Nov 11, 2008, 08:43:24 AM »
Just got word from Davez. that both t cases are approximately 13" from mating surface to rear output flange. I think i will verify this when i can get to a 4 cyl truck. Now the adapter will add to the length. so you will either have to reloacte the hanger bearing with a drop plate with slots to accomoadte the different length or retube the rear driveshaft.
OOPS
  • Male Posts: 2,561
« Reply #9 on: Nov 11, 2008, 03:43:33 PM »
When I put the single gear drive case in I did not have to modify anything. There was enough adjustment in the center bearing mount. The adapter is only about 3/4 " thick. The shifter that came with the case had been modified so it came up in the same place as the CD t-case shifter.
MaXXis85
« Reply #10 on: Nov 12, 2008, 11:05:53 AM »
Hell you are giving me the idea of doing a single case first. IDK what the hell to do. The only drawback is super low reverse. Suxor for the mud running we do down in south LA.
Last post Feb 25, 2006, 03:47:21 PM
by derek
Last post Sep 02, 2009, 10:43:32 PM
by Slolyfe
Last post Nov 19, 2009, 09:57:11 AM
by 4runner freak
Last post Nov 11, 2009, 06:19:58 PM
by 86toyota
Last post Dec 17, 2014, 05:44:04 PM
by Aaronm
