taco sas
Started by E YOTA, October 08, 2008, 08:33:32 AM
E YOTA
anybody know the specs on a front spring hanger for a taco sas so i can build one ? or buy one cheap, thanks
built lastnight, crawl today...
Ramrod
depends on what axle your using or how much lift you want.  If your using a toy axle you can just use a standard spring hanger but if your using a waggy or chevy axle it will be different
kiyul4130
search noob. toyota width, 29", dana width is 31.5 or 32. of if you narrow an axle it can be different. theres lots of info out there.
-kiyul-
ECV 7-11
KYOTA FOREVER
E YOTA
looks like i'll be using a pair of 44s off an wagoneer....and using marlins 5" springs...thanks
Ramrod
I hope not the rear 44
bigarms23
trade the rear 44 for a d60or d70
E YOTA
wats the problem with the rear 44? i just want them to match...not building a heavy duty crawler, just something i can wheel and hunt, with a solid axle... spent too much money on the last build... thanks for all you info.....
Ramrod
stock tacoma rear is probably alot stronger than the dana 44
RABIDYOTA
toy axles all the way why would you install a weeker axle????????
